Engine compression 1.3 DTE
Is there anyone who knows if i can watch the engine compression with op-com?
If yes,in which menu?
What's the level for each cylinder in a car without problems...?
Compression test
Hello everyone,
Want to do a compression test on my petrol Astra J...how long should I wait for the car to stall after I remove the fuel pump relay???
Tried the other day and it was it was idling for 20-30 mins without stalling...is that normal???
Low compression
Hello,
15 days ago my astra j 1.7 CDTI went into safe mode. I drove the car back to home in limp mode for about 10km. Day after I was booked in local garage. But the car has no power. Suddenly, after 200m the car stopped. It starts for 2sec and again stop... To cut the story garage was diagnose totally corked DPF filter. Cause: two injectors were corked by bad fuel. Anyway, DPF is now out completely (strait pipe) and remap done and injectors repaired. But now, service struggle to adj
Zero compression advice please
Hello as this is my first post,
After some advice please if anyone has encountered this issue before. I have bought a 2010 Astra J 1.4 VVT ( A14XER engine if it helps ). It overheated and the previous owner wanted rid so I bought it to try and get my nephew away from his ipad and experience some spannering! I didn't pay much for it as worst case I thought then we could just put a new engine in if it's really knackered.
So the experience so far.... cranks over fast and compression test show
