Radiator bottom brackets
Noticed today that my two bottom radiator mounting brackets are crumbling away with corrosion. The car is a 60 plate, has anyone else had this happen on their car?
Flat Bottom Steering Wheel
Just came across this, won't lie...I don't know what the current value is of these, but I'm sure this is way less than what I saw them going for a few years back!
https://www.ebay.co.uk/itm/2010-Vauxhall...SwQN5ae2fV
insignia flat bottom steering wheel into astra j?????
as title .... will an insignia 2010 flat bottom steering wheel fit into an astra j???
Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts?
Hi folks,
I'm about to change the rear shocks on my car, and according to the info on the Vauxhall workshop manuals website the bottom bolt that connects the shock to the suspension arm should not be reused, but a new one fitted.
The torque settings given are to tighten initially to 150 Nm, and then tighten a further 65 degrees. This suggests to me that it's a stretch bolt. Am I correct?
In all the years I've replaced shock absorbers on various Vauxhall cars, this is the first time I've
