Blower issue
im having issue with my blowers.
Basically whats happening when i press the button on control panel to stop or start blowers in one or two areas its not doing anything. Now on the control panel all the buttons work and light up. When pressing the three buttons in the dash displays show the message with arrows etc yet its not stopping or starting any blowers.
I have checked the fuses none are broken.
Thoughts?
heater and blower panel
If anybody has any ideas I would be grateful. Today I have been changing over to an after market head unit. When I clipped the heater blowers panel into the new facsia , and reconnected the power to them they no longer work,no power at all. Is there a specific fuse to look for or have I some how blown the panel.
Zcubed - Replies:
Another blower issue..
Astra J 2010 1.4T Elite climate air direction selection-mind of its own problem!
[quote]
Hi everyone,
I have a 2010 Astra J 1.4T elite with dual zone climate control.
In AUTO mode, everything seems to work correctly, controls temp and directs air to windscreen vents, middle vents and footwell vents.
However if you manually select the air direction (the manual says all combinations are possible) by using the selector buttons, the individual buttons light up, the display shows that they ha
Zcubed - Replies:
Blower vents Dual Zone Climate question?
I'm having problems with what I think is my air direction blower motor that controls which vent or vents the air gets directed to.
Would be grateful for anyone who has a similar setup, to answer this question:
If you manually set the air direction to your feet only, do you get a lot, a little or none out of the windscreen or front vents, or does it ONLY come out on your feet?
Thanks in advance
Abc - Replies:
Blower issues
Hi.
I have a really annoying blower issue which is made worst now we are at this time of year. When pressing the buttons on the dash to direct air flow travel it’s random and does not direct the air in the direction selected. So this time of year when I want to demist the windscreen I sometimes have to spen 15mins pressing buttons and random combinations until I eventually hear the windscreen vent open and the direction of air finally starts demisting the windscreen.
Can anyone help or give an
