Is this wear on the rod and crank bearings normal?
Given that I have a 2.0CDTI engine (A20DTH) and that last winter I had the low oil pressure light pop up for a second or so when starting the engine in the morning, I thought I should replace the O ring on the oil pickup from the sump.
After taking the sump off and removing the O ring I did notice that it was stiff and brittle and I replaced it. Since the O ring was so brittle I decided to take a couple of bearings off and inspect them and the crank. I've uploaded some images.
Can someone
M32 gearbox all new bearings fitted
M32 gearbox with all new bearings and seals fitted. will need an input shaft seal which is under £10 as this was the only seal I did not get, looking for £200 the bearings where £155
[Image: https://hosting.photobucket.com/images/a...122319.jpg]
