Broken crankshaft bearing
Hi guys, hope you're all going good
I had a problem with my Astra's crankshaft so I would like to share with you my experience so maybe I may have some advice from you or even answer your questions if you have any.
Actually, a crankshaft bearing broke while driving on the highway which caused the engine to stop, after several attempts, the engine never started because it was blocked.
the breakage of the bearing caused damage to the crankshaft so I decided to change the crankshaft for a new one
Flywheel or release bearing
Just bought a 1.7 cdti with 125000 and noticed that when on idle it’s noisy and car vibrates but when i press clutch it stops also gear lever is jumping when in 1,3,5,6 gear but 2,4 are fine also wine in all gears so rebuild/new gearbox,im going to change myself just don’t know if to buy a new clutch/flywheel as the clutch feels perfect just under half pulling away [Image: https://uploads.tapatalk-cdn.com/2021081...2c91fc.jpg]
[IMG]https://uploads.tapatalk-cdn.com/2021
