Meriva B 1.7 A17DTS (130) Weird Starting thing
Car is the Meriva B 1.7CDTI the 130bhp model, been faultless pretty much, had a new battery a few months ago, Anyway its been coming up with the service vehicle soon message every now and again, but i gather that is for fault codes to be read? it doesn't show up all the time...
Anyway this morning i was out taking pictures somewhere, had driven there engine had been up to temperature and that before i arrived. Put the key in the Ignition had the radio on for 5 mins went to start a
gazz292 - Replies:
Rain sensor (meriva B)
Don't suppose anyone knows the difference between the round rain sensors, as fitted to corsa's, meriva B's, zafiras and some other vauxhalls,
They have a 2 letter code on them, SA, SB, SC and SD.
On ebay it seems the SD one is for the meriva B, i know the SC one is for corsa's, as i got one from a corsa at the scrappers,
I've wired it in... power and earth taken from the supply to the auto dipping mirror i fitted a few weeks ago (takne from the relevent pins on the BCM as if it were fa
gazz292 - Replies:
CD400, in meriva B, mid-speed can-bus off, wont allow can learn
Wondering if anyones had this before?
2011 meriva B (1.3 cdti) CD400 with GID,
always been getting the following code on the radio: U0074
[attachment=978]
The other 2 codes are for the IPC, as im still messing with it...
but i was getting that U0074 code when i only had an op-com for diagnosis, so it's not the clone tech2 giving a fake code, and i was getting it before i ever touched anything electrical in the car.
The Tech2 gives an option to do a can bus re-learn on most module
Auto Dim rear view Mirror (Meriva B)
Bought myself an Astra J Elite Mirror with the auto dim function, This is to fit on the Meriva B. Just doing my research so i can connect it properly to the BCM to get the signal for when its in reverse.
It came with a rain & light sensor, but from another user on here It needs to have the SD Code on it :( so might try and sell the sensor. Would like to fit auto lights and the rain sensing wiper thing.
[Image:
https://www.mk3oc.com/forum/media/meriva....2116/full ]
edomali - Replies:
Meriva B GID problem
GID on my Meriva does not operate anymore and there is no audio on my radio. Do i have to divorce GID from donor car,or it is just plug&play? And what coult mean info on GID"Not avaliable vhile vehicle is moving"? That message is displayed all the time.
milozic - Replies:
Insignia B cluster fitted in Astra J
