car hasitates when accelerating
So when i drive from work to home and the car is cold it sometimes stops accelerating for a split seccond usaly around 70 kmph, sometimes it happens wile i'm allready at speed.
it only seems to do it when i'm on a late shift and happens only in the firts minute.
any ideas what i could be? probably going to the dealer tommorow.
thanks
edit: i have the 1.4 turbo petrol
Over revving when accelerating
Got a problem and hoping someone can help.
I've recently bought a GTC 2.0 CDTI SRI. ( 2012, 51000 miles ) had it around 4 weeks and have an issue already.
The only way to describe the fault is its as if I press the clutch pedal while accelerating. usually around 60-70 and in 5th are sixth gear although its done it once in fourth. it starts accelerating ok then loses power and starts over revving just like I have pressed the clutch in. I let of the accelerator or drop down a gear try to ac
