kmy - Replies:
P0480-00 fan low speed don't work
I have DTC P0480-00 and low speed engine fan don't work.
Fuses 42 and 48 are OK
Relay KR20C is OK
I need electrical diagram for engine fan for more test.
Engine A20DTH with AC
Please, help me.
Badenj - Replies:
P0030-00 HO2S heater control circuit sensor 1
Hi everyone
Been getting the SVS service message coming up with P0030-00 HO2S heater control circuit sensor 1
I’ve just replaced the lambda sensor for an identical part, cleaned the egr, throttle body and map sensor yet the fault won’t go away.
Any ideas of what this could be? Don’t really want to go to a garage and get raped of it could be this it could be that.
Many thanks.
Ruzty - Replies:
Code p242f-00
So my dpf light came on and noticed before that my astra would not do dpf regens anymore. I plugged in my tester and got these codes. I have to do a forced regeneration using the tester every 250km and these codes keep coming up. Do i need to replace my dpf filter?[Image:
https://uploads.tapatalk-cdn.com/2020080...cf7935.jpg ]
Sent from my SM-G965F using Tapatalk
