back exhaust pressure
Exhaust back pressure
Hi guys looking for abit of advice regarding exhaust back pressure psi? What is normal as mine is currently sitting at 14.4 psi at idle seems very high?
Not something I think most people really look into unless there is a problem.
I will look on TIS and see if it says anything.
Went into vauxhall for a dpf software update they wiped the ecu.... Picked it up yesterday drive less than. A mile and svs came on And went into limp mode!!
  1.7 CDTI - Stutters, then runs super rough, stalls and starts back up after 1h. rlievens 2 9,646 7:th-Aug-2021, 21:08:10
Last Post: Kiel0777
  Back box delete Kiel0777 1 3,286 1:st-Aug-2021, 23:55:26
Last Post: Cynide
  Exhaust middle box Kiel0777 0 2,447 23:rd-Jun-2021, 19:53:15
Last Post: Kiel0777
  High pressure air conditioning pipe Kiel0777 1 3,338 10:th-Jun-2021, 09:49:54
  Fitting valve exhaust system on VXR/OPC toxx 0 3,712 31:st-Mar-2021, 07:36:54
Last Post: toxx
  Exhaust sound Kiel0777 2 3,921 31:st-Jan-2021, 20:50:01
Last Post: Kiel0777
  duplex exhaust bosto 2 5,491 31:st-Jul-2017, 09:27:14
Last Post: bosto
