gtc exhaust astra
Astra GTC Exhaust
Hi guys
I am new to this forum and wondered if you could help me please?  My car failed its MOT on Friday due to needing a whole new exhaust.  My garage phoned around every motor factor in the area who did not have the part and eventually phoned Vauxhall who said that due to the GTC having a short run life, no after market parts were made.  Therefore the part needs to be ordered from Vauxhall direct, from Germany at a cost of over £800 and 3-5 working days.  Car is now out of MOT and cannot be driven as I assumed that a part would be sourced locally on the day or the next day at the very least.  When husband phoned Vauxhall to ask for part numbers they refused to give it to him as they knew he would try ebay.
This is really not on as they have effectively taken the choice away from the customer.  Any ideas on what the part numbers are and where I can source the whole exhaust system cheaper that Vauxhall?
Many thanks
What engine do you?
Also if you provide your reg I can get you part numbers.
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,532 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,052 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 3,565 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,798 12:th-May-2021, 14:29:50
Last Post: azajus
  GTC exhaust options johno1412 1 3,061 12:th-May-2021, 14:26:49
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,891 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,027 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,155 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,479 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 1,810 24:th-Jan-2021, 14:44:22
