removal roof console
Roof console removal
Hi All
My 2016 GTC has developed an annoying rattle from behind the roof mounted light and switch console. If I'm mobile and the rattling starts, if I then press the console, the rattling stops. I suspect some loose wires are rattling against the inside of the console. So, the question is, is it possible to remove the console unit without damaging it. I've taken a close look and it looks like it press fits in to position but I don't want to attempt to remove it in case I damage it. Any help would be gratefully received. Many thanks in advance, Ed
Here is a how-to to remove the part
https://www.vxoc.org.uk/forum/Thread-How...tesy-light
There is a how-to somewhere to fix your issue by putting a sponge up in there.
(9:th-May-2019, 08:00:43)Rusty2009 Wrote: Here is a how-to to remove the part
Hi Rusty
You've done it again. Thank you so much. I would never have managed to get the light unit out without your help. I'll have a look for the sponge fix. That makes a lot of sense. The rattle is really annoying and it seems to be getting worse. I'm going to have a go now. You won't believe this but I've just noticed another rattle from what appears to be behind the speedometer to the right of the main instrument panel. I'll have a look through the site to see what I can find.
I wanted to say thanks for your help Rusty and have left something that I hope you will find useful at  https://ufile.io/x7y3dhrv
Just copy and paste the link in to your web browser and then select the free slow download. I hope you don't already have this and that it is useful for you. All the best and with grateful thanks, Ed
Thank-you ed-b, I do have access to that but always handy to have it in that form rather than loading up another OS.
TonyP (20:th-Dec-2025, 19:31:48), judgeatsi (28:th-Jan-2026, 12:37:31)
