fm amplifier bypass
Fm amplifier bypass.
Hi ive just insalled a dab+ box to my m072.
However as I thought the glass aerial supplied is shocking.
So I want to fit a fm aerial converter from dab on wheels.
However it' not compatable with aerials with an amplifier.
So how can I bypass the amp and where will I find it??
Converters aren't very good.
You should see if you have the DAB antenna in the glass and maybe even the DAB amplifier in the rear. If not fitting them is easy and reception will be great.
Hi I'm sure I have the antenna in the glass where is the dab amplifier and what would it look like.
Thanks.
I'm not fully sure for the RHD J's but tucpal's tutorial mentions it https://www.vxoc.org.uk/forum/showthread.php?tid=19
