any j your you rust astra have ? on
Have you any rust on your Astra J ?
As I am someone who is the wrong side of 50, I can remember the days when cars would rust quite badly at a relatively early age.
Vauxhalls these days seem to be fairly well protected from rust, but what I'd like to ask is :
Have you had any trouble with rust on your Astra ?
What are any potential problem areas ?
Has anyone had any rustproofing done on their car ?
I had a recall on mine for rust where the water drainage hole in fuel filler area is traps water and rusts vauxhall drill a small hole fill it with spray grease and seal it again they did it on mine been fine mine was registered in 2012
(29:th-Jun-2017, 22:07:05)Dale90 Wrote: I had a recall on mine for rust where the water  drainage hole in fuel filler area is traps water and rusts vauxhall drill a small hole fill it with spray grease and seal it again they did it on mine been fine mine was registered in 2012
Pretty much everyone has had that carried out.
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,708 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,628 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,093 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,972 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 6,943 12:th-May-2021, 14:29:50
  Astra j gtc modifications BillyBryan 2 5,524 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 5,369 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,460 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 7,129 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,149 24:th-Jan-2021, 14:44:22
halmu (25:th-Mar-2026, 09:44:42)
