rusty
rusty
rusty can you find me the part number for the rear brake pads for the 5 105 please
PM me your reg I'll find it quicker lol
Front for 267mm J67
Kit, Brake Pads 13301207
Disc, Front Brake, 276mm DIA 13502044
Rear for 268mm J67
Disc, Rear Brake, 268mm DIA 13502134
Kit, Brake Pads 13319294
13300867 KIT, BRAKE PADS (AXLE SET) (FOR 268MM DIA. BRAKE DISCS, POC J67) (NLS.- USE 13411380)
13502134 DISC, REAR BRAKE, 268MM DIA. (FOR USE WITH POC J67 BRAKE SYSTEM)
Would seem that rear pads are the same for your brake system and mine,
thanks rusty so i need 13300867 pads
cool just got a set new with clips £25 ebay
http://www.ebay.co.uk/itm/281303918801?_...EBIDX%3AIT
my be a good idea rusty to add the VM brake kit codes and disc sizes to the how to remove service brake pads. :cool
Are you able get part numbers for the GTC's yet? If so if I supply my registration could you confirm the part number for rear pads and ideally confirm if they are the same as the Insignia. I know the front pads are the same but not sure on the rears.
don't think they have updated the TIS for the GTC as yet
but they should be the same as the j
but saying that the VXR has bigger discs and calipers
i know the biturbo calipers are much bigger they may be the same as them
John pm me your car reg and look for you.
Rusty does your tis cover the mk5 looking to find out if the rear rewind tool is the same adapter or size of the tool needed for the j
tucpal Wrote:Rusty does your tis cover the mk5 looking to find out if the rear rewind tool is the same adapter or size of the tool needed for the j
Look at this Vauxhall Workshop Manuals > Astra H > H Brakes > Rear Wheel Brake > Brake Pads > Repair Instructions > Replace brake pads on rear wheel brake
also this Vauxhall Workshop Manuals > Astra J > Brakes > Disc Brakes > Repair Instructions > Rear Disc Brake Pads Replacement
Although they have different tool numbers they look the same
pcd 32.5mm 6mm pins astra h
so sod it not wasting any money so pliers it is
Astra J GTC, DISCS AND PADS, PCD 5+115
FRONT DISC, 321MM 13502826
FRONT PADS, 13137751
REAR DISCS, 292MM 13502138
REAR PADS, 13300867
ASTRA J 5 DOOR, DISCS AND PADS, PCD 5+105
FRONT DISC, 276MM 13502044
FRONT PADS, 13301207
REAR DISC, 268MM 13502134
PADS SET, REAR 13300867
ASTRA J 5 DOOR DISCS AND PADS 5+115
FRONT DISCS, 300mm 13502051
FRONT PADS, 13301234
REAR DISCS, 292mm 13502137
REAR PADS, 13319294
Astra J VXR, DISCS AND PADS, PCD ????
FRONT DISCS 355mm 13370436
FRONT PADS 13411116
REAR DISCS 314mm 13371163 or 13429575
REAR PADS 13417473
RUSTY can you add the info for the 5+115 300mm
i will add this info in the too the how to for reference
good idea may be to merge the thread in the astra gtc section on brakes
in to the how to as there is some good info in that thread
at some point
add the info mate,
Don't know the PCD of the VXR
cheers i will add that to your how to on brake service
Pretty sure the VXR's PCD is 115 the same as the rest of the GTC's
i will try and find out i had a feeling it was 118 but i may be wrong
Cornishtaz fitted VXR wheels to his original GTC. Also the spare wheel I have fits the on the studs of my car just can't get it over rear callipers. The spare came from my Elite. Which reminds me I need to stick it on the for sale page.
i forgot about that 115 it is then
Rusty2009 (26:th-Dec-2023, 13:16:32)
