biggest ?? wheels
Biggest wheels ??
Hi all. What are the biggest wheels you can fit to the Astra j 2.0cdti SRI,bear in mind the Astra sri is lower than other models. I have the 225/50/17" atm. I'm currently looking at 235/40/19" do you think they would start to rub with luggage in the boot? These are the ones I'm looking at . https://www.ebay.co.uk/itm/172216806345 they said they would come with 235/40/19 tyres thanks.
Hi, I have an sri VX-line and from factory it comes with 235/40/r19 so you'll have no problem putting them on your car, in fact you could probably go for 20" if you're feeling brave.
(14:th-Jan-2017, 15:33:27)Astra VXD Wrote: Hi all. What are the biggest wheels you can fit to the Astra j 2.0cdti SRI,bear in mind the Astra sri is lower than other models. I have the 225/50/17" atm. I'm currently looking at 235/40/19" do you think they would start to rub with luggage in the boot? These are the ones I'm looking at. https://www.ebay.co.uk/itm/172216806345  they said they would come with 235/40/19 tyres thanks.
Got a 2010  1.7 cdti sri- currently running 235 40 19" came with the car - thought they were standard... no issues at all..
The Sri vx line comes with that exact size so should be perfect.
Past 2008 Civic 1.8 Type S
those are the vx line wheels in that size. I like the vxr replicas as well in 19 inch.
(14:th-Jan-2017, 16:40:07)marcus01 Wrote: those are the vx line wheels in that size. I like the vxr replicas as well in 19 inch.
Yes I was quoted £795 for those wheels with tyres in my link.
Those wheels have been put on numerous J's, mostly in Turkey as it has a more established modding scene. The offset is 42 which is fine and width is 8.5J which is the same as genuine 20" VXR alloys.
Mine came with 20" wheels from factory
(15:th-Jan-2017, 15:32:00)McGill2009 Wrote: Mine came with 20" wheels from factory
I should of said my cars is the 5door .GTC can take 20" but I don't think the 5door can.
You can have 20s just lesser profile tyres.
Hi I've got the gtc 2.0 cdti and was thinking of lowering and bigger wheels, anyone know the best comb?
Hi got a set of 19"vxr reps running 235 45 19 on my j 5door could I run 245 35 19 without any rubbing or anything tia
The GTC runs 20" wheels: 8½J x 20 offset 41, tyre 245/40R20 setup.
All the OEM wheel sizes for the Astra J are at bottom of this page.
as said above.. 20" with the right tyres for the rolling diameter..speedo will be out.! not sure if it can be calibrated to suit.
use this site
https://www.tyresave.co.uk/tyre-size-calculator/
Sent from my G3311 using Tapatalk
  Wheels 3_crispies 1 3,123 2:nd-Feb-2021, 09:49:07
Changed my wheels - what you think? Vx-Mad-G 8 8,338 14:th-Apr-2020, 09:07:53
Last Post: Vx-Mad-G
  What are these wheels off? GTC? Vx-Mad-G 3 5,863 7:th-Feb-2020, 09:46:41
Last Post: Vx-Mad-G
  Which wheels and tires Astra J 1.6 CDTi 110hp _Mita 1 5,794 31:st-Jan-2020, 09:38:19
Last Post: _Mita
  TPMS Sensors on wheels but not on car AphoticSketch 2 6,148 7:th-Nov-2018, 17:01:44
Last Post: AphoticSketch
  Wheels just been done Jayrich872001 10 10,223 19:th-Feb-2018, 18:10:34
  Dry, almost grinding type noise from front wheels / discs area rbull51 2 9,540 12:th-May-2017, 11:17:58
  Non GTC 20 inch wheels AphoticSketch 2 7,441 13:th-Sep-2016, 20:56:52
  Noise from front wheels/brakes richje100 1 6,610 23:rd-Aug-2016, 21:39:02
  Tyre choices 18" wheels andy2174 6 12,722 15:th-Apr-2016, 17:14:13
Last Post: andy2174
