j gm astra oil
Astra J GM oil
Hello,
I'm about to change the oil.. is this one correct for my Astra 2013 ST 1.7 tdci 96kw?
http://motoil.cz/cz-detail-1221093-gm-op...30-5l.html
Or should I buy other?
Thanks!
@rusty2009 should know this
(16:th-Dec-2016, 23:52:56)aurega Wrote: Hello,
Thanks!
Yes you need Dexos 2 GM oil or approved oil. I buy it for around £22.00 for 5 litres in the U.K. Buy it for less than that for 4 trade.
Yes correct oil for 1.7 but you need 5.4L
Thx guys! So I will order 5+1extra L.
(17:th-Dec-2016, 12:25:57)aurega Wrote: Thx guys! So I will order 5+1extra L.
Or buy 2 x 4 litres, use the extra for topping up. My prev Astra 2.0cdti s/s J used very little between yearly oil changes. My current 2.0d auto tractor uses around 1 litre of oil per 10,000 miles covered. You tend to pay a premium for the extra for 1 litre top ups.
My 2.0cdti uses's nothing in-between services I also bulk buy my oil and as it only uses 4.5L I save 0.5L up for another service.
My sump doesn't lose any oil, it ends up with too much due to failed regens because we only do 10 minute journeys on town roads all the time. Will probably do its 3rd oil change within a year in couple of weeks time to make sure the viscosity is okay and levels are maintained correctly. I may buy gm 93165557 oil this time though.
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,725 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,632 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,105 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,996 13:th-May-2021, 11:38:55
  Astra j gtc modifications BillyBryan 2 5,532 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 5,374 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,475 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 7,144 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,159 24:th-Jan-2021, 14:44:22
