headlight xenon numbers part
Xenon Headlight Part Numbers
I saw a 2010 5 door elite today with headlights like these:
[Image: 25092010011.jpg]
Are these standard? If so does anyone know the part numbers ( and if they will fit my J that's non xenon )
(sorry if I have posted in wrong section)
Thanks.
[Image: sig_zpsrr6dc7ua.png]
2012 Astra J 2.0 cdti sri
No they won't fit none xenon models. They need not only programming but major wiring changes.
AFL lights are optional extras. I don't think they are standard on the elite
As bhalay has said there are major wiring changes needed and also programming & GM no long support AFL retrofits.
Correct not fitted as standard to any model it's an option.
It seems I was luckily with the AFL retrofit I did.
(13:th-Aug-2016, 23:48:22)D92 Wrote: I saw a 2010 5 door elite today with headlights like these:
Thanks.
You can buy after market projector headlights which will look similar for around £300-£350 and they will be plug and play, so just a matter of fitting, but they are still xenon though.
Cheers all,
Was hoping they would fit, all the aftermarket lights dont look nearly as nice.
Closest I can find are the Magneti lights ( http://www.ebay.co.uk/itm/400968932903 ) but not sure If they will fit my 5 door, advert on ebay says both gtc and non gtc, but I thought the gtc had different lights or am I wrong?
They are GTC lights and will only fit a GTC.
These lights are nice...
[Image: 7ee83bb9b57560a124bcf793fe0bfda5.png]
They can be found here... http://www.ebay.co.uk/itm/VAUXHALL-ASTRA...SwzJ5Xf6jm
  coolant pipe part number livo 1 3,299 10:th-May-2024, 17:41:23
  Navi 650 Screen Surround Part Number Jetcolour 9 29,956 4:th-Jan-2021, 14:01:10
Last Post: MarkAP68
  Headlight Switch Disassemble Jetcolour 3 9,099 15:th-Dec-2020, 20:51:36
  Part Number Required Traders 2 9,039 23:rd-Sep-2020, 08:50:29
Last Post: Traders
  Need help identify part. LucasBritish 1 9,565 22:nd-Jun-2020, 11:48:35
  Need help identify part. LucasBritish 2 5,006 22:nd-Jun-2020, 11:44:44
Photo Looking for this part, see picture Budd 3 12,759 15:th-Feb-2019, 18:41:41
Last Post: Budd
  looking for part number then try here. Rusty2009 10 20,099 11:th-Jan-2019, 11:48:11
Last Post: Ykrats
  Boot rubber thing part number Telsun 0 9,966 2:nd-Jan-2019, 21:07:37
  Need a Part number Eddie0892 10 16,275 22:nd-Nov-2018, 14:05:53
