cd400
CD400
Hi all.
I have an Astra J fitted with a cd400 head unit. There is an Aux button on the console, probably fitted as standard, is there an Aux socket at thexrear of the head unit? I was wondering if anyvof you know, save me pulling the unit out for nowt!
no only at the front
Oh well, don't have one of them either. Above the cigar lighter is a blank on the right where the usb port would've been and nothing the other side.
Thanks for the reply. I may have to buy new head unit then, but, so I've been told, with the loss of a few controls because will be double unit.
(26:th-Jul-2016, 17:46:44)tenby2 Wrote: Oh well, don't have one of them either. Above the cigar lighter is a blank on the right where the usb port would've been and nothing the other side.
Or get the M072 head unit from icebox auto and it replaced your current orange screen and you keep all your controls
Thanks I will look up the MO72
Thought they all had aux?
Mine has the standard aux button on the console but not aux input pointand so I was told earlier in this thread there isn't one on the back of the cd400 either. So i wonder if the M072 will work in my astra!
There isn't an aux port at the back of radio but AUX is hard wired into the main radio plug.
So you can reinstate the factory AUX, you may even find the plug behind the dash.
Cheers Rusty, I will have a butchers and hopefully get lucky?
(27:th-Jul-2016, 14:04:41)tenby2 Wrote: Cheers Rusty,  I will have a butchers and hopefully get lucky?
If not give me a shout as I have an Aux port here and could make you make a loom (small fee of course) so you can plug it all in, I may even have the housing for Aux somewhere in a box in the loft.
Thanks again I nay take you up on that offer. I will have look Saturday.
Awight Rusty. Never got the chance to remove the cd400 to have a look behind it. But will do asap, hopefully this week, and will defo get back to you with results, I definitely want to get a USB socket in my Astra..
Finally removed the cd400 console etc, fiddly but not too bad. And found out to the right of my cigar lighter there appears to be a 3.5mm jack socket, the aux in I presume! No help to me really I have nothing to connect to it. It's for an ipod I presume? I have no apple gear, strictly Android me. I will see what adapters are around, unless there's a way to connect a USB socket somewhere.
You should be able to connect any AUX device to it.
You can retrofit a USB I think there is a kit in the for sale section
https://www.vxoc.org.uk/forum/Thread-USB-Retrofit-kit
It will need a VCI tho.
Cheers Rusty, but I might try a 3.5mm male jack to USB female and go from there
  my 1st Astra J Audio Help CD400 NEATH-LAD 9 14,355 29:th-Dec-2025, 18:14:53
  CD400 usb and aux not responding ste88 6 6,373 22:nd-Aug-2021, 18:16:19
Last Post: ste88
  How To Fit Sub To CD400 Head Unit TUFFKNUX 138 178,597 20:th-May-2021, 09:19:58
Last Post: h4r7y
  CD400 Plus - what does the “Plus” Add? GordyC 9 21,122 12:th-Nov-2020, 10:41:15
  ad usb to cd400 Collie 5 7,225 9:th-Oct-2020, 16:56:47
Last Post: Collie
  GTC BT CD400+ ac1212 1 4,777 18:th-May-2020, 09:51:39
  CD400 buttons not working Android head unit install mephisto 4 12,134 27:th-Oct-2019, 17:30:00
Last Post: mephisto
  CD400 upgrade Astra vxr 2014 Nathan 6 8,830 22:nd-Oct-2019, 20:13:14
  Astra SRi CDTI VX Line - CD400 Upgrade options AdaKer 3 7,103 13:th-Aug-2019, 06:48:28
Last Post: Schiffers
  CD400 FAULTY kjohns80 2 5,652 7:th-May-2019, 11:05:06
adam@adamkimber.net (23:rd-Oct-2025, 16:32:12)
