12:th-May-2016, 13:15:35
Found this just wondered what it was for
| s what this for ?? |
What's this for ??
12:th-May-2016, 13:49:56
Could be for the washer bottle sensor that tells you if your fluid is running low... Guessing you don't have that feature at present? If not then that's where the tank with the sensor built into it would plug in
Hi mate I don't have that function but I put a multi meter to it and look like there is no power to it only 2 wires on it purple and black.
12:th-May-2016, 14:10:31
Yeah may not actually be wired up... I bought a tank for mine, plugged it in... Nothing happened lol. Plug is there but not wired up... Guess yours is the same
12:th-May-2016, 14:11:02
Just popped the bonnet on my car to see if I could see where it goes and I think it is the washer sensor my car has that function and its the only plug I can see wont that part of the engine bay
12:th-May-2016, 14:19:34
Yep as I thought then makes sense too as the plug is clear and so is the washer bottle...
12:th-May-2016, 14:27:15
So does that mean it's all dead or can this be fitted to work ?
12:th-May-2016, 15:13:23
It can be fitted mate I've got the coolant tank with sensor retrofitted
I only have the small ipc at moment with the errors that come up any cancel you can help out as was looking at getting them installed and working.
12:th-May-2016, 15:24:57
Andy from vx mods did my wiring for me... You'd have to contact him. Only charged me 20 quid or so
12:th-May-2016, 16:34:01
It's a finger... you can use it to pick your nose or point at things
12:th-May-2016, 17:51:16
12:th-May-2016, 18:03:51
andy.lamb@vxmods.co.uk
Drop him a mail Sent from my LG-H815 using Tapatalk |
« Next Oldest | Next Newest »
