database experts access
Access database experts
Anyone know anything about access database. I'm trying to write some code but really stuck. TIA
(17:th-Mar-2016, 14:47:52)cornishtaz Wrote: Anyone know anything about access database. I'm trying to write some code but really stuck. TIA
Are you using access just as the database or writing an application inside access? Forms, vba, reports and stuff etc.
I know a man that might be able to depending on how busy he is and how big of a task it is.
Basically what I'd like to do is looking at the picture is
When a tick is put in the On Cal box the current date gets entered into Date Sent box and the date removed from the Date Returned box.
When the tick is removed from the On Cal box the date is removed from Date Sent and current date entered in Date Returned box
I've asked the question mate. I'll let you know when I get a reply
This is what I've been told. Means nothing to me but all the same.....
"yep that is possible. You use the after update vba command.boom!"
Thanks mate will give it a try
