headlight condensation
Headlight Condensation
Anyone know what causes this? Never seen it before and I've not done any work on the headlights so won't he any sealant issues.
It can happen every now and again when the lights are on in the rain it will clear or should do if it does not clear then you may have a problem
Ahhhh okay! Hadn't drove it for a few hours, got in for a 10 min drive and then noticed it. Gonna be driving another hour or so later so will see if it clears thanks
Its just condensation gathering in the corners or the cold spots it will clear after a good run with the lights on the condensation will be pushed through the vents on the back off the headlights in very damp conditions it will draw some damp air into the headlight this will clear with the lights on given time as the headlight gets hot inside it will push the water vapor out the vents on a dry day if this does not clear and I am sure it will then you have a problem
Ahhh I didn't know they went that far to ensure that kinda thing didn't happen! (putting vents in) it almost cleared anyway with my hour long drive if it doesn't go away then I'll get VX to sort it under warranty as with everything else lol
They will say if it clears within 30 mins it normal
I get this happening on my lights every now and then just after I have washed the car. I put my lights on dipped when driving the next day and as tucpal said it clears
  Headlight learn milozic 2 3,576 28:th-Mar-2021, 10:58:47
Last Post: milozic
  Headlight downgrade Boris.t 4 4,950 15:th-Oct-2020, 19:43:59
Last Post: Boris.t
  Headlight bulbs WoZLinGToN 3 6,660 26:th-Jul-2018, 13:44:46
Last Post: astra777
  Headlight Condensation sheppy1 2 4,806 27:th-Oct-2017, 08:12:48
  Headlight re-seal what buytl to use ? kyle-astra-j 10 13,144 20:th-Aug-2016, 18:22:07
Last Post: kyle-astra-j
  headlight bulbs bay 2 6,144 1:st-Jan-2016, 18:57:10
Last Post: Shorty S91
  Changing Headlight Bulbs And DRLs SI SRI 12 19,109 26:th-Aug-2014, 17:59:50
Last Post: SI SRI
