service emission control
Emission Control Service
So I have a big service on Monday and I've been told I should get an emission control service too which is only an extra £25 of my hard earned money. Now it was explained as a sort of engine flush along with flushing oil out or something before they put fresh oil in... Sounds beneficial! Wondering if you guys would recommend this or is it just a scam?
worth having done every now and again
Brill! Will do it then 25 quid ain't bad and in 33k miles it hasn't been done yet. Cheers dude
I asked my mechanic if an engine flush is worth it and he said no.
As for admissions they just chuck a can of fuel additive in the tank which is useless unless they go and fill the tank up to mix it.
Ahhhh so better off cancelling it then? As they have it down to do alongside the service. Only reason I said yeah was because my MPG is a little lower than it used to be and they said they put fresh oil in the car and it's better that they flush the old oil out first
I was told you will never get all the oil out and when put a flush additive in some of that will also remain which is not good for the new oil.
Get a can of this & stick in the tank before you fill up it will do a far better job than what the dealership pushes.
http://m.ebay.co.uk/itm/AUDI-VW-PRO-TEC-...nav=SEARCH
They do say they will do a lot more than just flush the system... But whether or not they actually do this or not remains to be seen! Ha
Do a search on engine flushing you'll be surprised at all the cons of having it.
  Service vehicle soon(need better OBD2 Reader) Rocky33 13 15,855 7:th-Oct-2020, 15:41:56
  Service parts List Rusty2009 43 43,955 31:st-Aug-2020, 02:20:00
Last Post: M222RJF
  Astra J 63 plate traction control Liam12345 3 7,548 23:rd-May-2019, 20:31:27
Last Post: Liam12345
  Which service? dazzzdelux 3 8,425 19:th-Jan-2017, 08:35:07
Last Post: dazzzdelux
  2nd year service brake fluid change Rusty2009 11 20,029 6:th-Jun-2016, 22:07:03
Last Post: chudy85
  90,000 KM service Dman86 2 7,841 7:th-Mar-2016, 09:37:46
Last Post: Dman86
  Main service richje100 2 8,459 5:th-Jul-2014, 13:33:56
