1:st-Aug-2015, 21:57:11
Anyone recommend led replacement gor the above that are canbus friendly
Tags |
bulbs p21w |
P21W bulbs
1:st-Aug-2015, 22:33:24
this is what i use
http://www.hids-direct.co.uk/r580-w21-5w...air-white/ you wont need to worry about the canbus on the GTC it is not on check
1:st-Aug-2015, 23:21:03
Baz you have LED DRL/Sidelights having AFL don't you?
2:nd-Aug-2015, 08:37:42
(This post was last modified: 2:nd-Aug-2015, 08:38:26 by cornishtaz.)
Sorry should have ssid this is for the wifes Corsa. Reverse bulb is deffo on canbus
2:nd-Aug-2015, 08:56:31
Would have no idea about the new corsa as to what would wouldn't be error free. I guess if they throw up errors you could see if the 2 loads per bulb works on it.
2:nd-Aug-2015, 10:26:20
agreed no idea if they are on the cambus baz
check the corsa forums they will have the answer
2:nd-Aug-2015, 10:28:04
if they do put up errors my how to with the loads will work
sure there wired up the same |
Headlight bulbs | WoZLinGToN | 3 | 4,351 |
26:th-Jul-2018, 13:44:46 Last Post: astra777 |
LED Bulbs | Daz21 | 1 | 3,386 |
29:th-Mar-2016, 08:20:15 Last Post: Rusty2009 |
Reg plate bulbs | sheppy1 | 2 | 3,719 |
4:th-Feb-2016, 21:49:14 Last Post: sheppy1 |
headlight bulbs | bay | 2 | 4,182 |
1:st-Jan-2016, 18:57:10 Last Post: Shorty S91 |
Fog Light Bulbs (H11 55w) | sheppy1 | 2 | 3,799 |
25:th-Nov-2015, 19:27:44 Last Post: sheppy1 |
Change front bulbs | DC_ELiTE | 10 | 7,093 |
25:th-Oct-2015, 13:20:04 Last Post: CRNeo |
LED Canbus No Error Number Plate Bulbs | Rusty2009 | 9 | 7,951 |
20:th-Sep-2014, 22:57:19 Last Post: Rusty2009 |
Changing Headlight Bulbs And DRLs | SI SRI | 12 | 8,958 |
26:th-Aug-2014, 17:59:50 Last Post: SI SRI |
Fog light bulbs | JJ-Yorks | 4 | 4,888 |
22:nd-Jun-2014, 19:28:27 Last Post: Dicko |
What bulbs? | Cameron UK | 1 | 3,167 |
24:th-May-2014, 16:33:44 Last Post: tucpal |
