25:th-May-2015, 11:14:14
Are the flex floor for the 5dr and 3dr compatible?
Tags |
floor flex |
Flex floor
25:th-May-2015, 11:43:16
As far as I know the 3 door is larger
25:th-May-2015, 11:45:42
25:th-May-2015, 11:47:16
that's a bargain that. I'm trying to think who has a 3 door with it fitted they could take some measurements and I could compare them with mine.
25:th-May-2015, 11:57:50
I could measure my boot if you let me know what measurements you need
25:th-May-2015, 12:04:30
Ok I'll grab a pic of mine and add the measurement's on it in a min
25:th-May-2015, 12:37:48
Hopefully this make sense mate.
I do want to recheck the bottom measurement though. Astra-J 2.0 CDTI S/S
25:th-May-2015, 12:46:15
Measurements are virtually spot on except the one near tailgate which on mine is 2cm wider
25:th-May-2015, 13:12:49
Just rechecked the Bottom as I was sure I wrote it down wrong.
the floor is 1010MM (101CM) the outside to the side trims is 1030MM (103CM) Astra-J 2.0 CDTI S/S
25:th-May-2015, 13:14:02
I've just been checking part numbers and there the same for both. Just the side boot trim is different
25:th-May-2015, 13:16:18
Fair enough then I thought there was a slight difference in the boot shape.
25:th-May-2015, 21:13:34
Is there a big difference in the boot side trims just wondering if it'd be possible to modify my present ones
25:th-May-2015, 21:33:57
No mate it's just a rectangle cut out where the brackets are.
25:th-May-2015, 21:35:41
Cool should be any easy mod.
I'm hoping they post as it's 180 miles each way for me. [SIGPIC][/SIGPIC]
Flex ride shock absorbers and springs ? | Raf7007 | 6 | 6,384 |
15:th-Mar-2017, 08:37:48 Last Post: vocky |
Astra 2.0cdti sri puddle passenger floor | ricky spanish | 6 | 5,625 |
25:th-Sep-2015, 12:30:51 Last Post: tucpal |
