details afl retrofit
AFL Retrofit details
[Image: vx.o.c.jpeg]
This is another VX.O.C first retrofit.
I've spent many hours working on getting this retrofit working and I'm not going to give you all the information just so others can start charging people to do this for them.
Please take note this is not a How-to it's a guide for you to check your car to see if you can retrofit AFL
First off you need to check your fuse board in the engine compartment.
Please note these are pictures of a donor board.
[Image: 1.JPG]
Fuse's and relays
12 Adaptive forward lighting module
23 Headlamp washer system
24 Right low beam (Xenon)
25 Left low beam (Xenon)
33 Adaptive forward lighting
K05 KR2 HeadlampWasher Fluid Pump Relay
K06 KR49 Headlamp Low Beam Relay
You can check where all these are in the fuse's thread http://www.vxoc.org.uk/forum/Thread-Fuses 2nd post
If you have them it would be safe to say you have all pins underneath but it will pay to double check this.
So Disconnect the Negative terminal of the battery, then undo the 3 10mm bolts (they wont come out) you will feel a slight click when they are undone.
DO NOT REMOVE ANY FUSES OR RELAYS YOU DON'T NEED TO
[Image: 2.JPG]
Next get a trim tool and if you look on each side of the board you will see 2 clips just use the tool and praise them outwards and lift one Conner of the board at a time (Not too far just enough so they are un-clipped)
[Image: 3.JPG]
Then carefully lift the board up may need a wiggle and then turn it over and just make sure the bottom of the board has all pins in (in this picture you can see some are missing).
[Image: 4.JPG]
Refit the board Make sure you do not over tighten the blots but make sure they are done up nice and tight If your car wont start afterwards you've not tightened them up enough.
Parts list with part number's
If there is a * by it it means there two parts which are chassis dependent
[TR]
[TD]Item[/TD]
[TD]5 Door[/TD]
[TD]Price Autovaux[/TD]
[TD]5 Door[/TD]
[TD]3 Door[/TD]
[TD]Price
Autovaux[/TD]
[TD]3 Door[/TD]
[TD]Price
Autovaux[/TD]
[/TR]
[TR]
[TD]Xenon headlamp[/TD]
[TD]RH
13398145[/TD]
[TD]£520.99[/TD]
[TD]LH
13398144[/TD]
[TD]£520.99[/TD]
[TD]RH RHD
13377767
RH LHD
13377765[/TD]
[TD]£583.94
£583.94[/TD]
[TD]LH RHD
13377766
LH RHD
13377764[/TD]
[TD]£583.94
£583.94[/TD]
[/TR]
[TR]
[TD]Headlamp Assembly connector ZFW10-4 x2[/TD]
[TD]88988927[/TD]
[TD]£13.85[/TD]
[TD][/TD]
[TD][/TD]
[TD]88988927[/TD]
[TD]£13.85[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Control Unit, Headlamp Ignition x2[/TD]
[TD]13278005[/TD]
[TD]£208.50[/TD]
[TD]13278005[/TD]
[TD]£208.50[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Control Unit, Headlamp Ignition Ballast x2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]20950268[/TD]
[TD]£175.85[/TD]
[TD]20950268[/TD]
[TD]£175.85[/TD]
[/TR]
[TR]
[TD]Control Unit, Headlamp x2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]13377769[/TD]
[TD]£24.68[/TD]
[TD]13377769[/TD]
[TD]£24.68[/TD]
[/TR]
[TR]
[TD]Bulb 12V/35W, Headlamp, Xenon (D1S) x2[/TD]
[TD]93169040[/TD]
[TD]£113.40[/TD]
[TD]93169040[/TD]
[TD]£113.40[/TD]
[TD]93169040[/TD]
[TD]£113.40[/TD]
[TD]93169040[/TD]
[TD]£113.40[/TD]
[/TR]
[TR]
[TD]Bulb, 12V/55W, Headlamp, Cornering Light (H11) x2[/TD]
[TD]9270371[/TD]
[TD]£10.18[/TD]
[TD]9270371[/TD]
[TD]£10.18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Bulb, 12V/55W, Headlamp, Cornering Light (H7) x2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]93190461[/TD]
[TD]£5.93[/TD]
[TD]93190461[/TD]
[TD]£5.93[/TD]
[/TR]
[TR]
[TD]Bulb, Turn Signal, Silver (PY21W) x2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]13303563[/TD]
[TD]£11.23[/TD]
[TD]13303563[/TD]
[TD]£11.23[/TD]
[/TR]
[TR]
[TD]Socket, Bulb, Headlamp, Xenon (FOR D1S) x2[/TD]
[TD]12767661[/TD]
[TD]£4.15[/TD]
[TD]12767661[/TD]
[TD]£4.15[/TD]
[TD]12767661?[/TD]
[TD]£4.15[/TD]
[TD]12767661?[/TD]
[TD]£4.15[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Sensor, Headlamp Levelling, Front Suspension[/TD]
[TD]12845300[/TD]
[TD]£66.34[/TD]
[TD][/TD]
[TD][/TD]
[TD]12845300[/TD]
[TD]£66.34[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Plate, Exciter, Headlamp Levelling Sensor, Front Suspension[/TD]
[TD]13287929[/TD]
[TD]£5.47[/TD]
[TD][/TD]
[TD][/TD]
[TD]13287929[/TD]
[TD]£5.47[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Screw, Hex.HD., M6 X 20, Headlamp Levelling Sensor, Front Suspension x2[/TD]
[TD]11519376[/TD]
[TD]£0.79[/TD]
[TD][/TD]
[TD][/TD]
[TD]11519376[/TD]
[TD]£0.79[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Nut, M4.2, Plate, Headlamp Levelling Sensor, Front Suspension[/TD]
[TD]11516397[/TD]
[TD]£0.83[/TD]
[TD][/TD]
[TD][/TD]
[TD]11516397[/TD]
[TD]£0.83[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Screw, M4.2 X 20, Plate, Headlamp Levelling Sensor, Front Suspension[/TD]
[TD]11609457[/TD]
[TD]£0.76[/TD]
[TD][/TD]
[TD][/TD]
[TD]11609457[/TD]
[TD]£0.76[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Rivet Nut, M6, Headlamp Levelling Sensor, Front Suspension[/TD]
[TD]93299196[/TD]
[TD]£0.97[/TD]
[TD][/TD]
[TD][/TD]
[TD]93299196[/TD]
[TD]£0.97[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Sensor, Headlamp Levelling, Rear Suspension[/TD]
[TD]*13347457[/TD]
[TD]£80.03[/TD]
[TD]*13362768[/TD]
[TD]£88.99[/TD]
[TD]*13347457[/TD]
[TD]£80.03[/TD]
[TD]*13362768[/TD]
[TD]£88.99[/TD]
[/TR]
[TR]
[TD]Screw, Hex, Exciter, Headlamp Levelling Sensor, Rear Suspension[/TD]
[TD]*13353935[/TD]
[TD]£5.03[/TD]
[TD]*13338394[/TD]
[TD]£4.96[/TD]
[TD]*13353935[/TD]
[TD]£5.03[/TD]
[TD]*13338394[/TD]
[TD]£4.96[/TD]
[/TR]
[TR]
[TD]Nut, M6, Headlamp Levelling Sensor, Rear Suspension[/TD]
[TD]11507067[/TD]
[TD]£0.79[/TD]
[TD][/TD]
[TD][/TD]
[TD]11507067[/TD]
[TD]£0.79[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Screw, Hex.HD., M6 X 20, Headlamp Levelling Sensor, Rear Suspension[/TD]
[TD]11519376[/TD]
[TD]£0.79[/TD]
[TD][/TD]
[TD][/TD]
[TD]11519376[/TD]
[TD]£0.79[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Headlamp Levelling Sensor Connector ZFW3-37 x2[/TD]
[TD]93181753[/TD]
[TD]£16.52[/TD]
[TD][/TD]
[TD][/TD]
[TD]93181753[/TD]
[TD]£16.52[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Control Unit, Headlamp[/TD]
[TD]13366017[/TD]
[TD]£171.64[/TD]
[TD][/TD]
[TD][/TD]
[TD]13405836[/TD]
[TD]£167.42[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]K28 Headlamp Levelling Control Module X1 ZF18-6[/TD]
[TD]93187174[/TD]
[TD]£41.65[/TD]
[TD][/TD]
[TD][/TD]
[TD]93187174[/TD]
[TD]£41.65[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]K28 Headlamp Levelling Control Module X2 F6-16 (PRODUCTION NO. 90491162)[/TD]
[TD]13314092[/TD]
[TD]£20.12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Pump, Reservoir, Headlamp Washer[/TD]
[TD]13264299[/TD]
[TD]£41.44[/TD]
[TD][/TD]
[TD][/TD]
[TD]13264299[/TD]
[TD]£41.44[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
Bumper for headlamp washers Part number varies depending on options
headlamp washers Parts varies depending on bumper
Washer bottle Part number varies depending on model
Headlamp washer Hose Part number varies depending on model
Wire
Terminals
All the above prices are for brand new parts if you search around the internet you can find some great bargains like I did The Headlamp control module must be BRAND NEW.
You can also get good deals from dealers etc if you buy a bulk order of parts from them.
Some parts you have to buy in set quantity's (So I have some spare here)
You also need someone who can request the VCI code's via an MDI there is a set way to request the VCI code's for this retrofit as it's not recognized as a retrofit.
If people want this retrofit done I can do it.
It would take a Weekend to do so Friday to Monday as long as GM supply VCI code's on the Monday, the car would have to be left with me as it wont be derivable for safety reasons.
Pricing list
£200 if you supply all the parts including wire terminals & connectors.
Price includes labour & programming.
N.B Pricing can change without warning
  Front fogs retrofit Rusty2009 2 7,428 4:th-Nov-2014, 20:01:17
jas7c5-2008 (4:th-Jan-2026, 17:40:53)
