xenon headlamps
Xenon headlamps
Hi everyone my first ever post, I wanted to know if I can swap xenon headlamps over from halogen, I don't want to go through the hassle of afl system. I just want xenon lights. Will it be possible? Thanks
I'm working on seeing if this is possible, It just takes time finding the connector's I need from a scrap car.
rusty is working on it as he said
but the answer is no
there a completely different set up
and a lot of wiring will be needed
inside and outside the headlight
but rusty has worked out how to do the AFL
other options are aftermarket headlamps with projectors
or retro fit projectors into the headlamps
Ok, I'll keep checking to see if any updates thanks.
  Help with Xenon ballast placement edgarosm 4 6,888 8:th-Jan-2018, 08:23:16
  Xenon Angel Eye Halo's Rusty2009 24 23,010 3:rd-Jan-2016, 12:55:47
Last Post: cornishtaz
  Xenon Headlights sheppy1 8 10,205 14:th-Jun-2015, 17:35:04
Last Post: bhalay207
  AFL / Xenon retrofit matteh88 6 9,575 11:th-Feb-2015, 19:58:50
  Retrofitting bi-xenon projectors KAS7866 1 6,711 8:th-Feb-2015, 18:07:01
