Trade Count:
0)
Threads: 22
Thanks Received:
1 in 1 posts
Thanks Given: 2
1
Car: cascada elite and mokka exclusive
Sex: Male
Total Feedback: 0
Just sorting the parts to fit a calearo fm/am dab shark fin and I read that it will need 2 12 v power supplies. Is there a how too on fitting one of these as I don't fancy messing up looking for 2 12v to connect it to. Because to be honest i have never been any good with electrics and i don't want to make a mistake.
thanks
Wayne
Trade Count:
4)
Threads: 359
Thanks Received:
8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
It only has 1 12v power.
Best place to take it from is the purple wire on the back of the 12v socket.
Trade Count:
4)
Threads: 359
Thanks Received:
8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Yes the take some finding.
Trade Count:
0)
Threads: 22
Thanks Received:
1 in 1 posts
Thanks Given: 2
1
Sex: Male
Total Feedback: 0
shark fin found and fully fitted thanks for you help rusty
Trade Count:
0)
Threads: 2
Thanks Received:
0 in 0 posts
Thanks Given: 1
0
Car: Astra J
Sex: Undisclosed
Total Feedback: 0
Hi. I’m about to fit one of the Calearo fins, FM/AM/DAB to my Astra J. I don’t have factory fitted DAB and I’m actually running this to an Android unit because FM signal has gotten worse from the stock radio and the unpowered windscreen antenna I used for DAB isn’t getting as many channels with decent reception as I should in my area. I’m hoping a powered fin will improve things.
In any case. How best to run the cables, presumably the FM/AM will take the old existing cable from the aerial to the headunit, but I’ll have a new one to run for the DAB and some power. I’m assuming there is some path that doesn’t involve removing the interior roof liner? Thanks!
Trade Count:
0)
Threads: 22
Thanks Received:
1 in 1 posts
Thanks Given: 2
1
Sex: Male
Total Feedback: 0
Hi you will need to drop the rear of the roof liner a bit to access the ariel I sent the cables from the shark fin across towards the driver side rear quater lite and down the roof liner, I found it easier to remove the roof grab handles drivers side and tucked them up into the roof liner as it seamed to make the job easier. I then sent the cable down the drivers side front piller and under the dash. some people may do it another way but that's how I did it, I hope this helps
The following 1 user says Thank You to Qaranc for this post:1 user says Thank You to Qaranc for this post
• Thebatfink
Trade Count:
0)
Threads: 2
Thanks Received:
0 in 0 posts
Thanks Given: 1
0
Car: Astra J
Sex: Undisclosed
Total Feedback: 0
22:nd-Jul-2023, 10:13:57
(This post was last modified: 22:nd-Jul-2023, 10:15:40 by Thebatfink.)
Hey thanks. Out of interest why did you install it? Curious if its likely to even have a great impact on my android headunit. Did you install it for something similiar or an oem retrofit, how does it perform?
Oh one more question. I’m assuming you come down the a pillar drivers side windscreen.. to get it tucked behind the dash nicely and into the centre console, where did you go on the dash / what parts did you have to uninstall.
