400 cd plus
cd 400 plus
Hey just after some advice i have just bought a zafira tourer 2015 it has the cd400 plus system with dab however no Bluetooth, my old car is the astra j with the cd400 but it has Bluetooth is it possible to take the Bluetooth module out of the astra and put it in to the tourer?
Many thanks
Andy
PM me the REG as most it should be built in unless yours is an early one with all separate modules.
Thanks for sending the reg over I can confirm that the radio fitted to your car is an AIO (all in one) with USB DAB+ & BT (BT also supports audio streaming).
When you push phone on the radio what happens?
(17:th-Aug-2020, 16:12:15)Rusty2009 Wrote: Thanks for sending the reg over I can confirm that the radio fitted to your car is an AIO (all in one) with USB DAB+ & BT (BT also supports audio streaming).
thanks for your reply, when i push the phone button it just mutes the system
That is very odd I wonder if someone has swapped the radio and installed the wrong box.
Could be worth pulling it out and seeing if you can get the part number or a pic of the label I'll soon tell you.
Hi sorry for delay in replying here is all the codes from the radio
557799431
4114356a00049904
7310500000000x
It's the correct radio then.
So can be either the BT has gone faulty on it may need reprogramming.
(21:st-Aug-2020, 17:54:44)Rusty2009 Wrote: It's the correct radio then.
thanks for you help rusty, is programing something i can do from home? also i have been in the head liner and there doesnt appear to be a mic for the bluetooth
Programming if you have a MDI and access to SPS then yes you can.
How very strange is there a connector up for the MIC?
Hi eveyone, i own a zafira tourer model july 2015 and its fitted with cd400 plus.
However i was lately thinking to possibly replace the cd400 plus with navi 650/950, so my question to y’all is, is that possible and would it need extra wiring/programming?
Thanks in advance Otman
(30:th-Jan-2023, 12:47:43)Otman Wrote: Hi eveyone, i own a zafira tourer model july 2015 and its fitted with cd400 plus.
Yes extra wiring is needed and then programming of the Navi unit.
milozic (31:st-Oct-2023, 20:48:01)
