with unit orginal parrot ck3100 microphone
Orginal microphone with Parrot CK3100 unit
Hello,
Is it possible to use original microphone from Astra with Parrot CK3100 unit?
Original microphone has 3 wires: black, red, blue. Parrot mic cable has black and white. it's standard 3.5mm jack.
Is it possible to connect that cable with original microphone?
Which colors i need to use to connect it?
Thanks!
Any info maybe from someone?
I tried using a factory mic with my kenwood double din, although I got it to work it put so much noise through the mic no-one could hear me.
I guess that original mic has some noise cancelation.
I have another sper microphone. Maybe i willl try.
Which wires did you use?
I used the wire that came with the Kenwood mic.
Then I tried some microphone cable, and a new jack.
jas7c5-2008 (29:th-Dec-2025, 18:56:19), dread123 (6:th-Mar-2026, 15:43:37)
