funny on going
Funny Going On
Astra SE Tourer 2011
Just got back and opened door to get out.
1. The front courtesy lights did NOT go on (as normal)
2. Both rear courtesy lights DID GO ON
3 Checked and the front courtesy lights are still working by the rocker switches.
4. Locked the car and the rear courtesy LIGHT (nearside only bulb) REMAINS ON - the other goes OFF
I checked the settings in configuration and they are as set when I first got the car.
In the end I removed the LED's from the rear courtesy fitting as I do not want a flat battery in the morning
Any ideas?
Could be the car throwing a wobbly.
Have you tried the pull neg off battery for 30-60mins to let all systems fully shut down?
(14:th-Nov-2017, 08:54:35)Rusty2009 Wrote: Could be the car throwing a wobbly.
Hi Rusty, I was about to do that but had another idea and just sorted it - I put the LED's in a month ago and went easy and AOK (no problems)
Last night I took out the rear LED's completely as they would not go off (battery drain possibility).
So, this morning I decided to remove all the LED's, I found one of them was broken (physically) and the thin edge connector was in the socket but the rest hanging off.
I removed it completely and inserted a good one and now the door opening is back to normal.  I also replaced the rear courtesy LED's the way they were.
Must have got a dodgy one - luckily got some more coming tomorrow (spares).
I will keep your battery idea in mind for the future though, thanks
Requan (8:th-Aug-2025, 14:13:41)
