hello
hello
I am interested in mechanical & electrical elements of all Vauxhalls, I do have global tis & tech 2 device which I have modified my Corsa D 1.3 however I just had to replace & reprogrammed my new ECU & I previously replaced my IPC about a year ago, however I can't seem to get my car to start & I was wondering if it had anything to do with the replacement IPC immobiliser which wasn't programmed to the original ecu & tech 2 is showing as security code status not entered
Any solutions
Regards
Mark
Welcome to VXOC.
Put simply tech2 is very limited on the newer Vauxhalls they use the MDI and SPS online.
Its saying your security code isn't programmed to the IPC, this wouldn't stop your car from starting.
What else has been done just before car wont start?
Is tech2 pulling any other faults up?
