facelift pre grill bumper?
Facelift grill pre-facelift bumper?
Does anyone know if the facelift vxline grill will fit the pre-facelift vxline bumper?
There isn't a facelift vx line grill, vx line Astra was discontinued prior facelift I think The biturbo has the same bumper as vx line I believe.
(13:th-Jul-2016, 18:30:58)stigeye Wrote: There isn't a facelift vx line grill, vx line Astra was discontinued prior facelift I think The biturbo has the same bumper as vx line I believe.
Ok would it fit?
Im assuming mine is pre facelift its 2012
Yes, Astra VX line is pre facelift, can't say 100% whether they are exactly the same fit but there is a few visual difference that I can see, one is the badge and trim that the badge sits on. The badge on the facelift sits at the bottom of the grill, whereas on the vx line the bages sits at the top of the grill. From looking at a few images on google for the facelift bumper it looks as though there's a small semi-circle notch cut out of the bumper where the badge sits, and at the bottom of the bumper it is moulded to look like it sticks out a bit, a bit more agressive look.
You may be able to get away with just replacing the vx line top grill and trim with a facelift badge and trim?
Biturbo...
VX Line
(13:th-Jul-2016, 21:46:39)stigeye Wrote: Yes, Astra VX line is pre facelift, can't say 100% whether they are exactly the same fit but there is a few visual difference that I can see, one is the badge and trim that the badge sits on. The badge on the facelift sits at the bottom of the grill, whereas on the vx line the bages sits at the top of the grill. From looking at a few images on google for the facelift bumper it looks as though there's a small semi-circle notch cut out of the bumper where the badge sits, and at the bottom of the bumper it is moulded to look like it sticks out a bit, a bit more agressive look.
Biturbo...
VX Line
Thats a great help mate thanks! The thing i dont like about my bumper is its not aggressive enough looking. I tried to look for a splitter but there arent any to fit the vxline only the standard bumper. I want to change my lower grill to honeycomb but then realised that the upper grill wont match it (reason for this post). Unless i can maybe cut away the black bit and replace it with honeycomb aswell somehow.
No vxline bumper became facelift bi turbo bumper there slightly different and no part will fit the standard bumper
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,129 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  VXR Front Bumper onto a 5dr Bear 2 6,553 3:rd-Oct-2020, 11:48:59
  BiTurbo Rear Bumper Dudderz 3 6,926 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 4,039 13:th-May-2020, 14:56:05
Last Post: paula9568
  De-badged grill Seb90 6 7,055 2:nd-Mar-2019, 19:54:05
Last Post: Seb90
  VX Line / Ltd Edition Bumper Wanted crosser74 1 5,415 29:th-Jan-2019, 08:05:23
  de-badge grill marky79 1 4,624 16:th-Apr-2018, 08:59:56
Last Post: rlievens
  GTC rear bumper lower valance fitment? HST125 3 6,871 19:th-Dec-2017, 18:52:55
Last Post: stigeye
  Debadged facelift grille cstevens92 2 6,045 1:st-Nov-2017, 18:35:00
Last Post: cstevens92
  Astra J 5 door facelift bumpers Iaintruten 5 8,246 30:th-Oct-2017, 16:40:35
Last Post: Iaintruten
