sheppy1 progress thread
Progress Thread: Sheppy1
Bout time she did something! anyway... Another mod under my belt... Ridiculously bright boot lights!
very good
Nice going to do this on my K also going to add a glovebox light
(14:th-Feb-2016, 21:01:51)cornishtaz Wrote: Nice going to do this on my K also going to add a glovebox light
Is it the same on the K too with the crappy boot light?!
Yep.
Don't even have a glovebox light.
Oh my God! They managed to go backwards! At least we got a glove box light in ours even if it is rubbish too!
Probably how they've managed to shed upto 200kgs in weight.
Haha take it they carried on the tradition of no space saver tyre then in the boot?
Daft question, is the standard boot light same as glovebox? I seem to think it's not but just wondering how boot lights turn on off? Just wouldn't want led ones on all time
What ya mean mate? The actual bulb holder isn't the same as the glove box one no...
Also not sure how they turn on and off but once the boot is closed the lights go off right away... Not sure why you think they wouldn't?
Just something that crossed my mind as I've never looked and know that glovebox one has a button that presses in when glovebox is closed.
Oh okay... Guessing it's something to do with the actual boot catch itself... Maybe when it's pressed in (when the boot is closed) it sends a signal to turn the lights off? Only way it could work really
Yeah true, I'll be doing this shortly too! Also guessing no errors?
Good stuff! You'll be impressed with bow bright they are! And nope no errors as they're not on the Canbus and also no flickering or anything like that
Awesome thanks, I'll be gutted losing them from license plate but be worth the reverse camera when I eventually get it!
(14:th-Feb-2016, 21:58:22)Tonto Wrote: Just something that crossed my mind as I've never looked and know that glovebox one has a button that presses in when glovebox is closed.
Tell me more about this button.... The only reason I ask is my glove box light has never turned off when I close the door. There isn't a mechanism on the top of my glove box either so I've always been baffled as to how it works lol
(14:th-Feb-2016, 20:52:51)sheppy1 Wrote: Bout time she did something! anyway...
Gaurantee you won't show her this haha
What the hell! There should be! When you open the glove box it let's the button pop out which turns the light on.. When you clove the box it should press the little button in which turns it off... So you're doesn't have it at all? Just a hole where one should be or has it got stuck or something?
Yeah as Sheppy said mate. There will be a hole at top and should have a piece of plastic sticking out that pushes in and out to turn on and off
Showed her...don't regret it either! haha
Hmmm, I'll have a look in the morning. I'm certain it never used to turn off.
Haha @sheppy1 you brave brave man!
This is what went through @sheppy1 mind just before he got stuck...
Hahahaha i looked cool as ***** in my head... Then not so cool getting bailed out by a woman walking her dog and a couple in their land rover lol
Haha, can't believe you got stuck mate, I mean come on you need to drop it into 2nd and crawl otherwise you put too much power down and you spin
Haha I did that!! Trust me... It was stuck! Ha
Think somebody needs abit of practice....
Grrrr!!!! hahaha
Just seen these on one of the europeans cars on the Opel J page...I want them!!! Ha
I'm not a fan of the white footwell. I've got red in all of mine but going to go green eventually
Really??? I love it...looks clean and effective too for what they're meant to do...illuminate the footwells so you can see things! Ha.
But...each to their own either way I like how they did the rear footwells...not sure how that would need to be wired up though to ensure the wires are tucked out of the way and also have enough slack to allow for the seats to go back and forth without them snapping...
I ran mine from front footwell light, under carpet and there's holes under seat where you can bring wire back out, this is under front seat.
Oh so you've done the rear ones too?! I would do that but would rather have a fresh wire for the rear ones... I'll probably go via the roof lining and down the centre pillar into the hollow floor and then up through that hole as you've done so again.. How does it work with the seat going back and forth... You're either gonna have to have loads of slack wire or something else... Not sure how you've done it
Seat doesn't affect it but bloody kids kicking them can get annoying lol.
Hahaha well in okay in that department will have to buy some more leds then and give it a go! Assuming the plastic black cover down the centre pillar to the floor just snaps off?
Haha as @Rusty2009 says seat doesn't affect it as it isn't attached to seat at all, I've used double sided tape and stuck it to carpet! There's a bump which lets you face the led backwards.
Oh yes! I know what you mean! Brilliant thanks for that guys
Looks like @sheppy1 has taken the advice and started practicing his driving skills
https://youtu.be/r0s-OFPhIEc
Christ....that dude needs a fireman to cut him out of it! hahaha
Right chaps...question here regarding Oil...Now VX flushed all the oil and put fresh stuff in only 3 months ago (done probably around 5k miles since then). But the oil life indicator which is nigh on useless to begin with is saying the health is at 13%...I don't know whether it really is that low already or if VX forgot to reset the calculator thing...
So is there any proper way for me to check if it needs changing? That's the issue with that oil life calculator...it doesn't actually check anything....it just estimates based on how long it's been in there and how much you're driving so if someone doesn't reset it then it's gonna show incorrect readings!
(15:th-Feb-2016, 12:21:04)sheppy1 Wrote: Oh so you've done the rear ones too?! I would do that but would rather have a fresh wire for the rear ones... I'll probably go via the roof lining and down the centre pillar into the hollow floor and then up through that hole as you've done so again.. How does it work with the seat going back and forth... You're either gonna have to have loads of slack wire or something else... Not sure how you've done it
Mate you can just tuck the wires in through the centre console (it's what I've done, everything is pushed underneath and the wires tuck under the plastic side boards of the centre console. It's quite easy to do
@Tonto there's green for you mate
Thanks mate, definitely going green haha!
I can pick and choose with my multi coloured lights
can even change the brightness haha
That looks awesome! And yeah I know what you mean now! I could even splice into the existing wire which I have running through the console which gives the driver side footwell lights power... Sweet! Ta
Oh bright
(15:th-Feb-2016, 19:40:04)sheppy1 Wrote: That looks awesome! And yeah I know what you mean now! I could even splice into the existing wire which I have running through the console which gives the driver side footwell lights power... Sweet! Ta
That's what I meant by running it under carpet from front footwells lol
Well why didn't you say that! Hahaha
(15:th-Feb-2016, 12:13:38)Tonto Wrote: I ran mine from front footwell light, under carpet and there's holes under seat where you can bring wire back out, this is under front seat.
But I did..
I know mate I just totally didn't understand! Haha cheers though
Still don't know if it's worth getting a K and n filter.... Someone help me decide! Ha
Got some LEDs coming for the rear footwells and also a K&N air filter ordered too
Yey sorry for delay! Yes good choice mate!
Ha it's fine and you mean on the air filter or LEDs @tonto?
  Progress thread Rusty2009 Rusty2009 416 331,783 27:th-Mar-2022, 09:32:35
  Progress thread : White Astra 2.0 Cdti Sri vx line marcus 193 159,656 1:st-Aug-2021, 11:24:07
  Progress thread - AstraRT AstraRT 5 7,336 10:th-Jan-2021, 08:35:22
  Qaranc's Astra progress Qaranc 12 15,138 7:th-Nov-2020, 08:06:37
  Alex's Progress Thread AlexFitton 95 76,030 27:th-Jun-2020, 08:53:48
  Sparkyscfc74’s progress thread sparkyscfc74 485 696,456 13:th-Jun-2020, 08:24:38
  JohnL's VXR Progress thread JohnL 17 20,844 15:th-Feb-2020, 12:38:28
  Where's my thread? Telsun 2 5,893 1:st-Jan-2019, 09:49:57
  Progress Thread Conor97 Conor97 28 23,033 9:th-Sep-2018, 19:37:44
  Progress thread sports tourer chills21 6 12,459 5:th-May-2018, 17:12:03
Users browsing this thread: 9 Guest(s)
