j overheating astra 4t 1
Astra J 1.4T Overheating
Hi all looking for advice
My Astra has recently started having overheating problems, Its had a new Thermostat and the waterpump has been removed and checked and is functioning correctly but it still seems to overheat, It'll sit happily on 90 during idle but after 3-5 minutes of driving it'll overheat and creep upto the 110-130 mark and advise the engine has overheated and to idle the engine. I was wondering if anyone else has had an issue like this and what my next steps should be?
Airlock maybe or coolant temperature sensor maybe?
(16:th-Aug-2020, 18:06:55)Jpbroad1970 Wrote: Airlock maybe or coolant temperature sensor maybe?
Coolant Temp Sensor is built into the thermostat from what i can see, Every time I've had to replace coolant I've vacuum bled it afterwards. I'm really picking my brain on what else it could be
UPDATE: After checking the breather/return pipe we've uncovered it had been glued back together (by a previous owner) after being broken and then caused the pipe to block, causing the engine to overheat
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,544 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,102 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 3,595 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,812 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,904 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,049 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,176 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,516 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 1,831 24:th-Jan-2021, 14:44:22
  Astra J workshop manual Euroshopper 1 1,977 9:th-Jan-2021, 08:09:36
