little mod
Little mod
So I decided to replace the boot light with one of these:
http://www.ebay.co.uk/itm/230879251093
They are the same as the footwell lights.
They come with adapters so they just plug straight in to the original socket and can be attached on the outside to the see through cover.
I then decided I wanted one either side, so I spliced into the original wired behind the light then ran a cable under the sil to the other side. I then attached the 2nd led board to a a sheet of plastic, drilled a hole through then bolted the. Together to hold it in.
Sorry about the mess lol
[MENTION=40]WhelanUK[/MENTION] u recognise the card I used?
they should be a lot brighter
tucpal Wrote:they should be a lot brighter
The pictures don't do justice, this was pitch black at night, they are very bright in real life
I added an extra light in the boot awhile ago and it does make a huge difference, although I did get the fitting and cut a hole in the trim to fit it and I just put LED in.
Rusty2009 Wrote:I added an extra light in the boot awhile ago and it does make a huge difference, although I did get the fitting and cut a hole in the trim to fit it and I just put LED in.
I was thinking of that but decided on the squares due to the light output is so good
I like that might have a go myself
