Welcome back to the VXOC FORUM.
Sorry for our lack of support over the last year but MYBB is back and so are we.
Let's get the forum buzzing again... (March 25, 2022)x
Deffo a difference in picture and sound. I walk in and catch the missus watching SD TV and tell her off straight away when there's a HD channel available.
That's on a full HD 51" samsung smart 3d TV
Is your 32" full HD (1080p) or HD ready (720p)
What brand of TV is it? As some brands have poorer image processors than others. For example Anna's uncle has a 40 inch Bush TV and there is next to no difference between HD and SD the picture just looks rubbish no matter what format its in.
Also I remember been told years ago that unless you sit close in front of the TV it's hard to tell the difference between HD and SD on the smaller TV screens.
LG's are usually good we have a few in work dotted around the office and you can tell when they are switched to 720 never mind 1080. Is your Sky box set to automatic or manually set for what outputs it sends out. I've seen it in the past where when it's on Auto it doesn't always send out a signal at 1080. Also did the sky engineer set it up or did you? Reason I ask is my parents had a similar thing which was down to the way the Sky engineer had connected it all up. TV and Sky box were connected with a Scart cable and HDMI cable. The TV was auto selecting the scart signal even though they had selected HDMi Resolved the issue for them by removing the scart lead.
Set it up myself only Used a HDMI cable, I do believe it's set to 1080P on the sky box but will check later.
Mind my box has been playing up quite alot lately keeps locking up when fast forwarding etc I've done the de frag via the hidden menus but not made a difference.
Mine played up around the start of this year would freeze when fast forwarding or rewinding or some times even just pausing live tv. In fact on demand stuff would play for 10 minutes and then freeze or you would loose sound. I ended up having to do a full factory reset on it can't remember the button combination for that but it has improved the box functions. Although the on demand stuff I have to let it download fully before I start watching it otherwise it will only play about half the show/film.
Anyway as for HD content is this with any content you watch that you can't tell any difference between SD and HD. Because not all the shows on say BBC1 are recorded in HD.
What are your download speeds like anyway you think think that's bad try BT vision it used to to be grate till they did an update last year and now I player is useless forward and rewind have a mind of there own and the remote just stops working when ever it wants a load of tosh that
Network speed for me is great. pretty much 100mb all the time with Virgin. So waiting for it to download the on demand stuff before watching it is no great hardship. Usually by the time the kettle has boiled it's finished downloading. I believe the issues with my box was down to all the dust from whilst I was doing the house up. Knocking walls down and plastering etc. Should have seen the dust that came out of unit once we had finished on the house.
