19:th-Jul-2020, 02:39:37
Hi all
im going to be retrofitting front fogs to my SE bypassing the BCM and wiring them in myself
but i have the switch unit out of an sri that has the front and rear buttons
as im trying to keep it as standard as poss i would like to know if anyone has a pin out of the switch unit
or knows which pin in the load signal pin to go to the relay
i have included a quick diagram on how i am going to run the fogs
so one you know what im talking about and two if anyone else wants to try it so you dont need to get a VCI code
as i believe with the switch unit and op-com you can turn on the IPC light so that will come on like normal when you turn the front fogs on and off
thanks dsknectd
thanks dsknectd
