please help
PLEASE HELP
Dpf soot level shows 131%.. No fault codes on the car and the dpf Differential sensor is reading 102kpa... Been for a very long drive today down the m1 doing 65 in gear 4 at 3k revs but soot levels are still the same?
I really don't know what to say that will help you
my 1.7 suddenly came up with the "dont stop driving" message as I pulled onto my drive, so I went back out for a thrash, it blew out loads (and I mean LOADS) of black crap.
I don't know what the soot levels are on my car, but usually when they get too high you get the message that I got , aftre that it goes into limp home.
I'm no expert, but if yours is at 131% then either your diagnostic tool is lying to you
or
maybe your dpf filter etc has been removed by a previous owner and the computer system still shows the level when it went into "limp mode"
I think the only way to find out for sure is to get it looked at by a Vauxhall dealer or Vauxhall specialist
I used opcom which is vauxhall software
Only way to find out properly is to get it checked out properly.
op com is not vauxhall software and what you have is a copy any way.what you want is tech 2.belive what people are telling you your dpf is not blocked
Well what's wrong with it then as it's on 131% that is not normal levels and it's showing dfp differential sensor at 102kpa!
(12:th-May-2020, 14:58:52)niteram Wrote: I really don't know what to say that will help you
or
Reccomend any?
does it drive ok,have you got power in all gears,does it run ok,if so dont worry about
(12:th-May-2020, 16:59:21)paula9568 Wrote: does it drive ok,have you got power in all gears,does it run ok,if so dont worry about
Yes it all runs fine but I don't want it to get to the point of "limp mode" rather have it sorted now as something clearly isn't working properly
I can't recommend any near you as you're not local to me.
try this for your local Vauxhall dealer
https://www.vauxhall.co.uk
try a google search for Vauxhall specialists near you.
Yeah thanks I've found a local specialist... All signs are pointing to dpf Differential pressure sensor
