(14:th-Mar-2018, 10:03:59)Rusty2009 Wrote: Looking good changing any more?
Thanks mate I think the air con button blue and if it can be done change the fog light switches to match how they appear on the clocks, green for the front and yellow for the rear?
(15:th-Mar-2018, 08:54:46)Rusty2009 Wrote: Cool I did the tell on the aircon green.
But yes you can on the fog lights that's how I did mine.
Xenon switch
Normal switch
Cool, that’s what I had in mind
Is there a how to for the fog light buttons at all and what type LED’s do I need?
I noticed for the air con button, it looks like it uses an 0805 for the illumination but looks like a plcc2 for the light in the switch, is this right?
I don't think a how-to has been done yet for headlight switch they are quite easy, un-clip the toggle switch (grey tabs) then un-clip the back (mind the springs don't fly out)
they use 0805 leds 9 iirc (depends what there as they all use different qty)
As for the Heater panel you are correct 0805's and the tell-tell's are PLCC-2 if you don't have dual climate control under the left knob (temp) is a PLCC-4 (White LED) which I never change as it lights up the Blue & Red.
(15:th-Mar-2018, 10:33:25)Rusty2009 Wrote: I don't think a how-to has been done yet for headlight switch they are quite easy, un-clip the toggle switch (grey tabs) then un-clip the back (mind the springs don't fly out)
Ok thanks for that I think I’ll give it a go. I feel a bit more confident now I’ve done a couple
Had a fairly productive afternoon, I’ve changed the air con “on” colour to blue and when my 0805 LED’s arrive I’ll be changing the illumination to blue also
I also said in my previous post that after changing the door unlock button to green that the red side wasn’t as bright so I changed it today and it wouldn’t work!! After the 3rd led I tried the original one and that still worked so I was baffled. I then tried one of my blue ones which also worked so I decided to spin the red led to try and it worked!! Whoever made my red LED’s must have the polarity the wrong way round so anyway that’s now sorted
Finally I’ve fitted a DPF regen light and put it in the top of the ipc
I've just noticed that my cruise control is no longer working nor does the symbol light up on the clocks but the speed limiter still works fine.
Has anyone else had the same problem?
18:th-Mar-2018, 15:12:43 (This post was last modified: 18:th-Mar-2018, 16:11:53 by sparkyscfc74.)
(17:th-Mar-2018, 13:26:15)sparkyscfc74 Wrote: I'm going to plug it in later, I have seen a re-learn clutch position but haven't clicked on it.
I’ve just plugged my op com in and tested the engine measuring blocks for the clutch and brake pedal, both read fine from 0% to 100%. The learn clutch position in the programming does nothing, there were no DTC’s present so I’m still baffled as to why the cruise control isn’t working?
One other thing though was after having my headlight switch out yesterday, since I’ve put it back in, the front fog light doesn’t light up on the clocks anymore but the fogs come on. I again looked for fault codes and it came up left cornering light open circuit?
Anyone got any ideas?
I’ve disconnected the battery for an hour to see if that does anything
Reconnected battery, made no difference whatsoever
I give up!!! Now my number plate lights have stopped working, message on the dash!!!! They’re LED unit so again I’m completely baffled
Just plugged my op com back in to see about the number plate lights not working and got a page of faults which I cleared but 4 would not clear
Checked the washer fuse that had blown the other day but it was fine I’m totally stuck ☹️
It seems that the problems have occurred after having the battery disconnected, shall I try disconnecting it again for another 30 minutes?Cheers for your help mate
I've just tried the old standard bulbs in the number plates and they don't work either, so I've disconnected the battery again to see if anything changes
(19:th-Mar-2018, 10:00:30)sparkyscfc74 Wrote: I've just tried the old standard bulbs in the number plates and they don't work either, so I've disconnected the battery again to see if anything changes
Connected the battery back up, made no difference again. Same faults coming up on op com. While I’d got it plugged in I did some output tests on the ipc like the dial sweep, dimming and lights which made all the symbols light up on the clocks and the cruise control light and front fog light both lit up so that rules out the LED’s being dead! I’ve been trawling the internet trying to look for similar problems but have drawn a blank ☹️
Just one more thing is that the rear washer is still working.
I think I've got serious problems!! Not only do I have no cruise control but now I have no front washers, no number plate lights, no reverse light, no reverse sensors, no reverse camera and no o/s rear indicator!!!! Just spoken to my local garage and he thinks that the body control module might have packed up!! Major expense!!!
19:th-Mar-2018, 21:43:09 (This post was last modified: 19:th-Mar-2018, 21:44:08 by Rusty2009.)
(19:th-Mar-2018, 13:39:41)sparkyscfc74 Wrote: I think I've got serious problems!! Not only do I have no cruise control but now I have no front washers, no number plate lights, no reverse light, no reverse sensors, no reverse camera and no o/s rear indicator!!!! Just spoken to my local garage and he thinks that the body control module might have packed up!! Major expense!!!
Try unplugging the plugs from the BCM and then replugging them in.
Failing that PM your reg and I can look into BCM part number and see what I can find for you.
The list of things not working is growing I’ve now got no ambient lights, headlight switch doesn’t light up nor do the electric window switches or door lock/unlock button, hazards and airbag light and both 12volt sockets are dead!!!
I’m going to have to go to a main dealer so god only knows how much it will cost!!!
Feeling for you here mate. Worst part is, you'll be guaranteed you'll get a moron at the dealer who will simply want to replace things until it goes away, without actually investigating the cause.
(19:th-Mar-2018, 21:56:40)umognog Wrote: Feeling for you here mate. Worst part is, you'll be guaranteed you'll get a moron at the dealer who will simply want to replace things until it goes away, without actually investigating the cause.
Right I checked the fuses and no19 had gone so I’ve now got back reverse light, camera and sensors, ambient lights, 12 volt sockets and the dash and switch lights.
So I’m back to no front washers or number plate lights.
(20:th-Mar-2018, 12:16:55)Rusty2009 Wrote: Look at fuse 40 in engine bay listed as 10amp on the washer diagram. the relay is non serviceable.
Fuse in engine bay 23 20A for number plate lights.
Hi mate fuse 40 is fine, there is an empty space in 23 but my handbook says that it’s for headlight washers. Strangely enough my rear washer works fine.
I’ve had a bit of a breakthrough with my cruise control. On my way to work this morning I was playing around with the switches and pressed the cruise control button and the +set switch at the same time, the cruise control then engaged with the green light on the dash and worked as it should!!! I got no white light before so I’m wondering if the white part of the LED has gone if that’s even possible?
(24:th-Mar-2018, 10:25:58)umognog Wrote: On mines I had two distinct different led, which is how I was able to change to blue + green using the smd's I had already bought.
(24:th-Mar-2018, 13:40:06)umognog Wrote: Pretty sure it was just 0805's
Cheers mate I’ve got some of them but they’re too small for me to work with until I’ve got a smaller tip for my soldering iron and a bloody big magnifying glass
Changed some of my tell-tell lights today on my heated panel , air con blue front screen green and direction buttons are now green
Just got to do the eco one green when I get some more LED’s
