when looking at 2013 onwards astra elite, im getting abtit confused with some of the ads, some say 160bhp some say165, are they the same spec or did the spec change at some point
| confused |
confused
20:th-Jan-2016, 19:10:25
Some engines have an extra 5bhp but as for the reason behind it I have no idea
20:th-Jan-2016, 19:17:27
so you could get either engin at the same time?
20:th-Jan-2016, 20:01:00
I think I'm wrong but my understanding was the 160 was non stop/start.
20:th-Jan-2016, 20:04:14
that makes sence
20:th-Jan-2016, 20:14:39
160 no stop/start 165 stop/start as Tonto said.
20:th-Jan-2016, 20:16:31
does the start stop run off starter motor, which one would your reccomend
20:th-Jan-2016, 20:56:01
It has an updated starter motor and different glow plugs.
I'd recommend the stop/start with 17" wheels then you pay £30 road tax, then just fit bigger alloys. Astra-J 2.0 CDTI S/S
20:th-Jan-2016, 21:00:35
thanks
20:th-Jan-2016, 21:09:27
the start stop does seem to have a mind of its own
sometimes it works others it does not not that i have my car in eco alot
20:th-Jan-2016, 21:12:00
so if the cars not in eco, s/s doesnt work
20:th-Jan-2016, 21:13:24
cheers,
20:th-Jan-2016, 21:14:54
(20:th-Jan-2016, 21:09:27)tucpal Wrote: the start stop does seem to have a mind of its own Many different factors at play mate, that why a complex system. Push the Eco button turns it off but you have to do that every time. Astra-J 2.0 CDTI S/S
20:th-Jan-2016, 21:21:53
it is a very over complicated system for sure
it started working the other day shock i said i have not seen that come on for weeks ha ha
20:th-Jan-2016, 23:02:57
(20:th-Jan-2016, 20:56:01)Rusty2009 Wrote: It has an updated starter motor and different glow plugs. I always wondered why I get slapped with the £110 road tax when it's the same engine... Is it the wheels? I'm on 19s
20:th-Jan-2016, 23:07:28
(20:th-Jan-2016, 23:02:57)Nemo Wrote:(20:th-Jan-2016, 20:56:01)Rusty2009 Wrote: It has an updated starter motor and different glow plugs. No I'm on 17s and I pay £110 a year, I just assumed it was because it isn't stop start... Sent from my iPhone using Tapatalk
20:th-Jan-2016, 23:14:48
17" with stop/start is £30 if you have 18-19" it goes up to £110
No stop/start is £110 and most likely goes up if you have bigger wheels. Astra-J 2.0 CDTI S/S
20:th-Jan-2016, 23:20:07
That's just stupid, charging nearly 4 times more for bigger wheels
20:th-Jan-2016, 23:20:55
They can't make you pay more tax by adding bigger wheels once you have car right? Just insurance?
20:th-Jan-2016, 23:27:10
Not as far as I know mate.
20:th-Jan-2016, 23:32:08
Ill be looking for a elite stop start on 17.s then will get the car to a spec i want.
