loud knocking
Loud knocking
So I've got a loud knocking coming from the front right wheel, seems to mainly happen when accelerating, revving stood still is fine. Does it whatever direction of wheels, quite loud, nothing loose that I can see. HELP!
Could be a wheel baring
Even though it only happens when accelerating? Sounds pretty metal if you know what I mean, not nice
I'd say pop it in a garage ASAP for a free inspection mate
as above mate and i would not waste anytime getting there
tucpal Wrote:as above mate and i would not waste anytime getting there
Booked in tomorrow, what noise did your car make when cv had gone?
Mate when my cv joint went on the left side it was a hollow knocking noise. Drove me mental.
more of a click on my car
but a knock when pulling off could be a number of things
and as your car is a cat d it needs to be checked over quiseng won't help at all
tucpal Wrote:more of a click on my car
That's the corner it had the bump on as well, will see at 5pm
Took it to the garage (my luck it had stopped making the noise) both cv joints that side were split so hopefully the problem is the joint, got a new one coming from Ireland for £90.
did you get the whole shaft
this does seem to be a common problem on the j
i think the shaft is a bit too long my self
but sure you will get it sorted.
Yeh from gear box to hub, Vauxhall said it is most likely the issue due to the cv boot leak. Wouldn't be covered under warranty as that's where it had its crash, this kinda thing u have to expect with a cat D
yep but still nothing that major it should be back to normal soon
Just noticed it doesn't happen when in neutral, not sure if if it's gonna be the drive shaft? Maybe cos it's the shaft it's under power when in neutral?
you would only get a knock or click when in drive it will be a cv joint on the shaft
neutral has no effect on the drive shaft at all
what do you mean under power ?
tucpal Wrote:you would only get a knock or click when in drive it will be a cv joint on the shaft
I mean maybe when it's in neutral it's not putting strain on the joint therefor not knocking?
correct for a minute i thought you were saying it was knocking in neutral never mind
you will have it sorted out soon it probably just had a knock on the wheel when it was banged
Cam have you got it fixed yet?
NOPE.. not done yet
Rusty2009 Wrote:Cam have you got it fixed yet?
Part arrived today, hopefully Wednesday get it fitted
Is it all fixed now?
Not yet, hadn't had the noise in a while, new drive shaft had a split cv boot as well! Seller had bought a brand new one from vx and is in the post, should have it fitted Saturday
Users browsing this thread: 8 Guest(s)
