Trade Count:
( 4)
Threads: 359
Thanks Received: 5 in 5 posts
Thanks Given: 1
70
Sex: Male
Total Feedback: 0
Are they easy to come off got polish on mine wouldn't mind getting them painted and the ones around the windscreen and bonnet.
Trade Count:
( 0)
Threads: 13
Thanks Received: 0 in 0 posts
Thanks Given: 0
0
Car: GTC 2.0cdti SRI
Sex: Male
Total Feedback: 0
Ah I see! Well that’ll be interesting to see. I keep toying with the black roof look but all white maybe the way to go (if I ever get as far as that!). What are those roof trims even for!?
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
6
Car: VXR
Sex: Male
Total Feedback: 0
25:th-Mar-2019, 09:25:00
(This post was last modified: 25:th-Mar-2019, 09:25:53 by vocky.)
(24:th-Mar-2019, 19:13:07)Rusty2009 Wrote: Are they easy to come off got polish on mine wouldn't mind getting them painted and the ones around the windscreen and bonnet.
they are held on with several plastic clips and simply lift straight up, I used one of those plastic trim tools to help it unclip. The plastic clips are quite fragile and are riveted to the roof.
(24:th-Mar-2019, 19:15:19)Telsun Wrote: What are those roof trims even for!? to cover up the welded joint between the roof skin and the side body panels
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
6
Car: VXR
Sex: Male
Total Feedback: 0
25:th-Mar-2019, 13:13:03
(This post was last modified: 25:th-Mar-2019, 13:40:19 by vocky.)
this morning I whipped the front bumper off and fitted the front park assist sensors and wiring loom.
Just got to swap over the module, but not got the time at the moment.
Not a very good photo, was in a hurry lol
The central two black sensors are circled in green
Had a few extra minutes, so swapped over the module.
Front sensors are working and so is the IPC, result
will get some better photos later
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
70
Sex: Male
Total Feedback: 0
25:th-Mar-2019, 13:51:04
(This post was last modified: 25:th-Mar-2019, 13:51:50 by Rusty2009.)
Looking good mate. Is the rear sensors showing on the IPC too?
First VXR to have factory fitted sensors retrofitted.
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
6
Car: VXR
Sex: Male
Total Feedback: 0
Just the front sensors on the IPC, exactly what I wanted
Trade Count:
( 0)
Threads: 7
Thanks Given: 0
3
Total Feedback: 0
It looks very good. How did you manage to fit the front 2 that are in the center? Could you take some better pictures?
This is my roof mate, how yours will look. Much better
Enviado do meu SM-G950F através do Tapatalk
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
6
Car: VXR
Sex: Male
Total Feedback: 0
25:th-Mar-2019, 16:24:00
(This post was last modified: 25:th-Mar-2019, 16:27:55 by vocky.)
just got back from the bodyshop
(25:th-Mar-2019, 15:23:53)Jonika21 Wrote: How did you manage to fit the front 2 that are in the center? Could you take some better pictures?
I had to modify the foam block behind the bumper. I just cut away some of the foam to give enough room for the sensors and wiring plugs, the outer sensors had loads of space.
I will get some better pics
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
70
Sex: Male
Total Feedback: 0
Need to do the window ones too tho as it looks abit odd now I think.
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
6
Car: VXR
Sex: Male
Total Feedback: 0
26:th-Mar-2019, 09:13:19
(This post was last modified: 26:th-Mar-2019, 09:14:56 by vocky.)
(26:th-Mar-2019, 08:09:39)Rusty2009 Wrote: Need to do the window ones too tho as it looks abit odd now I think. it looks perfect in the flesh, the photo does not really capture the effect
I must say that without Rusty and this website none of the retro-fits would ever have happened to my car, thank you Mr Rusty
I will try and get a picture today of the roof from a short distance and a better picture of the location of the front sensors
Trade Count:
( 0)
Threads: 7
Thanks Given: 0
2
Car: GTC Bi-Turbo
Sex: Male
Total Feedback: 0
Vocky
Very impressive indeed, the car looking is looking superb, all of the modifications that you have done to the VXR have been without a doubt been well worth the effort.
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
6
Car: VXR
Sex: Male
Total Feedback: 0
26:th-Mar-2019, 17:49:16
(This post was last modified: 26:th-Mar-2019, 17:54:59 by vocky.)
(26:th-Mar-2019, 15:17:39)marktourino Wrote: Very impressive indeed, the car looking is looking superb, all of the modifications that you have done to the VXR have been without a doubt been well worth the effort.
thank you
My astra is now perfect in my eyes, exactly how I want ot to be. Well maybe after it gets a sunroof lol
The retro-fits have changed an average vxr into a fully loaded top of the range vxr, every retrofit has been a great idea and I would recommend them all.
Better pictures of the roof trims and the location of the front sensors;
It still looks better in the flesh, must be the angle the pictures are taken or something ...
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
70
Sex: Male
Total Feedback: 0
I'm still not sure on the windscreen trim remaining black it looks out of place going from white to black it just doesn't flow now if that makes sense?
I'm wondering what else you can retrofit now lol.
What about as your into engines a nice 2.0cdti lump modified up to a high BHP and having a one off VXD lol.
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
6
Car: VXR
Sex: Male
Total Feedback: 0
27:th-Mar-2019, 12:13:21
(This post was last modified: 27:th-Mar-2019, 12:14:33 by vocky.)
I think it's because the photos are 'straight on', from any other angle they look great
Current power is over 330 bhp, which was only about £1k to achieve.
Going past that power level gets very expensive, very quickly.
ps: xenons would be a nice touch lol
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
70
Sex: Male
Total Feedback: 0
(27:th-Mar-2019, 12:13:21)vocky Wrote: I think it's because the photos are 'straight on', from any other angle they look great ![Smile Smile](https://vxoc.org.uk/forum/images/smilies/smile.png)
Yeah I would image the cost go high.
AFL, should be possible there are a few VXR's with AFL, @JohnL maybe the man to speak to see if your specs match.
Trade Count:
( 0)
Threads: 41
Thanks Given: 0
0
Car: Astra J VXR
Sex: Male
Total Feedback: 0
Looking at what has been retrofitted I'd say they are very close.
Sent from my H8216 using Tapatalk
Trade Count:
( 0)
Threads: 7
Thanks Given: 0
3
Total Feedback: 0
(26:th-Mar-2019, 08:09:39)Rusty2009 Wrote: Need to do the window ones too tho as it looks abit odd now I think. It's a no for me. No chance that it will look good colour coded too..
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
6
Car: VXR
Sex: Male
Total Feedback: 0
I recently replaced the exhaust system (cat back) with a Scorpion non res set up, which is quieter than the OEM system
I had to chop the old one into four sections to get it off, wish I had a car lift lol
Trade Count:
( 0)
Threads: 4
Thanks Given: 0
6
Car: VXR
Sex: Male
Total Feedback: 0
No more updates because I have part ex'd it in for a BMW M2 Competition
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
70
Sex: Male
Total Feedback: 0
Such a shame you did alot to it.
