Thanks Received: 5 in 5 posts
70
21:st-Feb-2014, 11:18:42
(This post was last modified: 31:st-Mar-2022, 18:49:00 by Rusty2009.)
PLEASE NOTE THAT FUSE RATINGS VARIES ACROSS THE RANGE IT IS YOUR RESPONSIBILITY TO CHECK THE RATING AND REPLACE LIKE FOR LIKE
VXOC WILL NOT BE HELD ACCOUNTABLE FOR ANY DAMAGE CAUSED TO YOUR VEHICLE.
Fuses
Engine Compartment Fuse box:
1 Engine control module = 20 A
2 Lambda probe = 10 A
3 Fuel injection, ignition system = 15 A
4 Fuel injection, ignition system = 15 A
5 –
6 Mirror heating = 7.5 A
7 Fan control = 7 A
8 Lambda probe, engine = 7.5 A
9 Rear window sensor = 7.5 A
10 Battery sensor = 5 A
11 Trunk release = 7.5 A
12 Adaptive forward lighting module = 5 A
13 – = 25 A
14 Rear window wiper = 20 A
15 Engine control module = 10 A
16 Starter = 30 A
17 Transmission control module = 10 A
18 Heated rear window = 30 A
19 Front power windows = 30 A
20 Rear power windows =30 A
21 ABS = 40 A
22 Left high beam (Halogen) = 10 A
23 Headlamp washer system = 25 A
24 Right low beam (Xenon) = 15 A
25 Left low beam (Xenon) = 15 A
26 Fog lights = 15 A
27 Diesel fuel heating = 30 A
28 – = 30 A
29 Electrical parking brake = 30 A
30 ABS = 60 A
31 – = 5 A
32 Airbag = 5 A
33 Adaptive forward lighting = 15 A
34 – = 7.5 A
35 Power windows = 7.5 A
36 – = 10 A
37 Canister vent solenoid
38 Vacuum pump
39 Fuel system control module
40 Windscreen washer, Rear window washer system = 10 A
41 Right high beam (Halogen) = 10 A
42 Radiator fan = 40 A
43 Windscreen wiper = 30 A
44 – = 30 A
45 Radiator fan =
46 –
47 Horn = 15 A
48 Radiator fan = 60 A
49 Fuel pump = 20 A
50 Headlamp levelling = 10 A
51 Air shutter = 5 A
52 Auxiliary heater, diesel engine = 7.5 A OR 10 A
53 Transmission control module, Engine control module = 7.5 A OR 10 A
54 Wiring monitoring = 7.5 A
Glovebox fuse panel:
1 Displays
2 Exterior lights
3 Exterior lights
4 Radio
5 Infotainment system, instrument
6 Power outlet front = 20 A
7 Power outlet rear seat = 20 A
8 Left low beam = 30 A
9 Right low beam = 30 A
10 Door locks
11 Interior fan
12 –
13 –
14 Diagnostic connector
15 Airbag
16 –
17 Air conditioning system / heater control panel 10 A
18 Prefuse: radio, Infotainment, displays
19 Brake lights, tail lights, interior lights
20 –
21 –
22 Ignition switch
23 Body control unit
24 Body control unit
25 –
26 Power outlet load compartment
Rear electrical centre:
1 Trailer module
2 Trailer outlet
3 Parking assist
4 –
5 –
6 –
7 10A Seat heating control module, seat lumbar control module - passenger
8 Anti-theft alarm system
9 –
10 –
11 Trailer module, Trailer socket
12 –
13 Trailer outlet
14 –
15 7.5A Inside rear view mirror, rain sensor, vehicle direction camera, Wing mirror movement.
16 5A Inside rear view mirror
17 20A Accessary power receptacle - cargo (Estate with rear body fuse block)
18 –
19 Steering wheel heating
20 Sunroof
21 Seat heating
22 –
23 –
24 –
25 –
26 30A Feed for fuses F3, F8 and F32
27 –
28 –
29 –
30 –
31 Amplifier, Subwoofer
32 Active damping system, Lane departure warning
Fuse Types
Fuse Types |
[TR]
[TD]Current Rating Amperes[/TD]
[TD]Color[/TD]
[/TR]
[TR]
[TD]Auto Fuses, Mini Fuses[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]Gray[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]Violet[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]Tan[/TD]
[/TR]
[TR]
[TD]7.5[/TD]
[TD]Brown[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]Red[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]Blue[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]Yellow[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]White or Natural[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]Green[/TD]
[/TR]
[TR]
[TD]Maxi Fuses[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]Yellow[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]Light Green[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]Orange or Amber[/TD]
[/TR]
[TR]
[TD]60[/TD]
[TD]Blue[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]Red[/TD]
[/TR]
[TR]
[TD]J-Case Fuses[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]Blue[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]Pink[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]Green[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]Red[/TD]
[/TR]
[TR]
[TD]60[/TD]
[TD]Yellow[/TD]
[/TR]
![[Image: vx.o.c.jpeg]](https://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Logo/vx.o.c.jpeg)
70
6:th-Oct-2014, 10:45:45
(This post was last modified: 31:st-Mar-2022, 18:53:02 by Rusty2009.)
X50A Fuse Block - Underbonnet Label
X50A Fuse Block - Underbonnet Label Usage
Underbonnet Fuse Board |
[TR]
[TD]No.[/TD]
[TD]Device Label Name[/TD]
[TD]Device Assigned Name[/TD]
[TD]Rating[/TD]
[TD]Description[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]1[/TD]
[TD]F1UA Fuse[/TD]
[TD]10A
20A[/TD]
[TD]K20 Engine Control Module (ECM) (Petrol)
K20 Engine Control Module (ECM) (Diesel)[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]2[/TD]
[TD]F2UA Fuse[/TD]
[TD]10A[/TD]
[TD]B52A Heated Oxygen Sensor 1, B52B Heated Oxygen Sensor 2, B75B
Mass Air Flow/Intake Air Temperature Sensor, E41 Engine Coolant
Thermostat Heater, Q12 Evaporative Emission (EVAP) Purge Solenoid
Valve, Q22 Intake Manifold Tuning Solenoid Valve[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]3[/TD]
[TD]F3UA Fuse[/TD]
[TD]15A[/TD]
[TD]Q17A Fuel Injector 1, Q17B Fuel Injector 2, Q17C Fuel Injector 3, Q17D
Fuel Injector 4, T8 Ignition Coil[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]4[/TD]
[TD]F4UA Fuse[/TD]
[TD]15A[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]5[/TD]
[TD]-------------[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]6[/TD]
[TD]F6UA Fuse[/TD]
[TD]7.5A[/TD]
[TD]A9A Outside Rearview Mirror - Driver, A9B Outside Rearview Mirror -
Passenger[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]7[/TD]
[TD]F7UA Fuse[/TD]
[TD]5A[/TD]
[TD]KR20B Cooling Fan Medium Speed 1 Relay, G10 Cooling Fan Motor[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]8[/TD]
[TD]F8UA Fuse[/TD]
[TD]7.5A[/TD]
Mass Air Flow/Intake Air Temperature Sensor[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]9[/TD]
[TD]F9UA Fuse[/TD]
[TD]7.5A[/TD]
[TD]K9 Body Control Module[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]10[/TD]
[TD]F10UA Fuse[/TD]
[TD]5A[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]11[/TD]
[TD]F11UA Fuse[/TD]
[TD]7.5A[/TD]
[TD]KR95B Tailgate Release Relay 1[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]12[/TD]
[TD]F12UA Fuse[/TD]
[TD]5A[/TD]
[TD]K26 Headlamp Control Module[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]13[/TD]
[TD]F13UA Fuse[/TD]
[TD]20A[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]14[/TD]
[TD]F14UA Fuse[/TD]
[TD]20A[/TD]
[TD]KQ7 Rear Window Wiper Relay, M45 Rear Window Wiper Motor[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]15[/TD]
[TD]F15UA Fuse[/TD]
[TD]10A[/TD]
[TD]K20 Engine Control Module (ECM)[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]16[/TD]
[TD]F16UA Fuse[/TD]
[TD]30A[/TD]
[TD]KR27 Starter Relay[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]17[/TD]
[TD]F17UA Fuse[/TD]
[TD]10A[/TD]
[TD]K71 Transmission Control Module[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]18[/TD]
[TD]F18UA Fuse[/TD]
[TD]40A[/TD]
[TD]E18 Rear Demister Grid[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]19[/TD]
[TD]F19UA Fuse[/TD]
[TD]30A[/TD]
[TD]M74D Window Motor - Driver, M74P Window Motor - Passenger[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]20[/TD]
[TD]F20UA Fuse[/TD]
[TD]30A[/TD]
[TD]M74LR Window Motor - Left Rear, M74RR Window Motor - Right Rear[/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]21[/TD]
[TD]F21UA Fuse[/TD]
[TD]30A[/TD]
[TD]K17 Electronic Brake Control Module (EBCM)[/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]22[/TD]
[TD]F22UA Fuse[/TD]
[TD]10A[/TD]
[TD]E13L Headlamp Assembly - Left[/TD]
[/TR]
[TR]
[TD]23[/TD]
[TD]23[/TD]
[TD]F23UA Fuse[/TD]
[TD]25A[/TD]
[TD]KR2 Headlamp Washer Fluid Pump Relay[/TD]
[/TR]
[TR]
[TD]24[/TD]
[TD]24[/TD]
[TD]F24UA Fuse[/TD]
[TD]15A[/TD]
[TD]E13R Headlamp Assembly - Right[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]25[/TD]
[TD]F25UA Fuse[/TD]
[TD]15A[/TD]
[/TR]
[TR]
[TD]26[/TD]
[TD]26[/TD]
[TD]F26UA Fuse[/TD]
[TD]15A[/TD]
[TD]E29LF Fog Lamp - Left Front, E29RF Fog Lamp - Right Front[/TD]
[/TR]
[TR]
[TD]27[/TD]
[TD]27[/TD]
[TD]F27UA Fuse[/TD]
[TD]30A[/TD]
[TD]KR22 Fuel Heater Relay (Diesel)[/TD]
[/TR]
[TR]
[TD]28[/TD]
[TD]28[/TD]
[TD]F28UA Fuse[/TD]
[TD]30A[/TD]
[TD]T19 Power Supply Transformer (KL9)[/TD]
[/TR]
[TR]
[TD]29[/TD]
[TD]29[/TD]
[TD]F29UA Fuse[/TD]
[TD]30A[/TD]
[TD]K83 Parking Brake Control Module (J71)[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]30[/TD]
[TD]F30UA Fuse[/TD]
[TD]60A[/TD]
[/TR]
[TR]
[TD]31[/TD]
[TD]31[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]32[/TD]
[TD]32[/TD]
[TD]F32UA Fuse[/TD]
[TD]5A[/TD]
[TD]K36 Inflatable Restraint Sensing and Diagnostic Module[/TD]
[/TR]
[TR]
[TD]33[/TD]
[TD]33[/TD]
[TD]F33UA Fuse[/TD]
[TD]15A[/TD]
[TD]K28 Headlamp Levelling Control Module (AFL)[/TD]
[/TR]
[TR]
[TD]34[/TD]
[TD]34[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]35[/TD]
[TD]35[/TD]
[TD]F35UA Fuse[/TD]
[TD]5A[/TD]
[TD]S52 Outside Rearview Mirror Switch, S79D Window Switch - Driver[/TD]
[/TR]
[TR]
[TD]36[/TD]
[TD]36[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]37[/TD]
[TD]37[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]38[/TD]
[TD]38[/TD]
[TD]F38UA Fuse[/TD]
[TD]20A[/TD]
[TD]KR28 Vacuum Pump Relay (Petrol)[/TD]
[/TR]
[TR]
[TD]39[/TD]
[TD]39[/TD]
[TD]F39UA Fuse[/TD]
[TD]20A[/TD]
[TD]K27 Fuel Pump Flow Control Module (Petrol)[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]40[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]41[/TD]
[TD]41[/TD]
[TD]F41UA Fuse[/TD]
[TD]10A[/TD]
[/TR]
[TR]
[TD]42[/TD]
[TD]42[/TD]
[TD]F42UA Fuse[/TD]
[TD]40A[/TD]
[TD]KR20C Cooling Fan Low Speed Relay (Petrol), KR20B Cooling Fan
Medium Speed 1 Relay (Diesel)[/TD]
[/TR]
[TR]
[TD]43[/TD]
[TD]43[/TD]
[TD]F43UA Fuse[/TD]
[TD]30A[/TD]
[TD]M75 Windscreen Wiper Motor[/TD]
[/TR]
[TR]
[TD]44[/TD]
[TD]44[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]45[/TD]
[TD]45[/TD]
[TD]F45UA Fuse[/TD]
[TD]30A[/TD]
[TD]G10 Cooling Fan Motor (Petrol)[/TD]
[/TR]
[TR]
[TD]46[/TD]
[TD]46[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]47[/TD]
[TD]47[/TD]
[TD]F47UA Fuse[/TD]
[TD]15A[/TD]
[TD]P12 Horn[/TD]
[/TR]
[TR]
[TD]48[/TD]
[TD]48[/TD]
[TD]F48UA Fuse[/TD]
[TD]60A[/TD]
[TD]KR20B Cooling Fan Medium Speed 1 Relay, KR20C Cooling Fan Low
Speed Relay, KR20D Cooling Fan High Speed Relay[/TD]
[/TR]
[TR]
[TD]49[/TD]
[TD]49[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]50[/TD]
[TD]F50UA Fuse[/TD]
[TD]10A[/TD]
[TD]S30 Headlamp Switch, M29L Headlamp Levelling Actuator - Left, M29R
Headlamp Levelling Actuator - Right[/TD]
[/TR]
[TR]
[TD]51[/TD]
[TD]51[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]52[/TD]
[TD]52[/TD]
[TD]F52UA Fuse[/TD]
[TD]7.5A[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]53[/TD]
[TD]53[/TD]
[TD]F53UA Fuse[/TD]
[TD]7.5A[/TD]
[TD]K20 Engine Control Module (ECM), K34 Glow Plug Control Module
(GPCM) (Diesel), K71 Transmission Control Module (A/T)[/TD]
[/TR]
[TR]
[TD]54[/TD]
[TD]54[/TD]
[TD]F54UA Fuse[/TD]
[TD]7.5A[/TD]
[TD]B19C Brake Servo Vacuum Switch, K27 Fuel Pump Control Module,
B116 Water in Fuel Sensor, E40 Electrical Auxiliary Heater, K33 HVAC
Control Module, P16 Instrument Cluster, B108 Air Quality Sensor, B19C
Brake Servo Vacuum Switch, B75B Mass Air Flow/Intake Air
Temperature Sensor, T19 Power Supply Transformer (KL9)[/TD]
[/TR]
[TR]
[TD]F01[/TD]
[TD]--[/TD]
[TD]F01UA Fuse[/TD]
[TD]80A[/TD]
[TD]K34 Glow Plug Control Module (Diesel)[/TD]
[/TR]
[TR]
[TD]F02[/TD]
[TD]--[/TD]
[TD]F02UA Fuse[/TD]
[TD]80A[/TD]
[TD]K43 Power Steering Control Module[/TD]
[/TR]
[TR]
[TD]F03[/TD]
[TD]--[/TD]
[TD]F03UA Fuse[/TD]
[TD]100A[/TD]
[TD]E40 Electrical Auxiliary Heater[/TD]
[/TR]
[TR]
[TD]F04[/TD]
[TD]--[/TD]
[TD]F04UA Fuse[/TD]
[TD]80A[/TD]
[TD]G10 Cooling Fan Motor[/TD]
[/TR]
[TR]
[TD]K01[/TD]
[TD]1[/TD]
[TD]SPARE[/TD]
[TD]----[/TD]
[TD]------------------[/TD]
[/TR]
[TR]
[TD]K02[/TD]
[TD]2[/TD]
[TD]----[/TD]
[TD]M64 Starter Motor[/TD]
[/TR]
[TR]
[TD]K03[/TD]
[TD]3[/TD]
[TD]KR75 Powertrain
Relay[/TD]
[TD]----[/TD]
[TD]KR29 A/C Compressor Clutch Relay, Fuses F1UA, F2UAF3UA, F4UA,
F7UA, F8UA[/TD]
[/TR]
[TR]
[TD]K04[/TD]
[TD]4[/TD]
[TD]KR5 Rear Window
Demister Relay[/TD]
[TD]----[/TD]
[TD]Fuses F6UA, F9UA, F18UA[/TD]
[/TR]
[TR]
[TD]K05[/TD]
[TD]5[/TD]
[TD]KR2 Headlamp
Washer Fluid Pump
Relay[/TD]
[TD]----[/TD]
[TD]G16 Headlamp Washer Fluid Pump[/TD]
[/TR]
[TR]
[TD]K06[/TD]
[TD]6[/TD]
[TD]KR42L Daytime Running
Lamp Relay- Left
OR
KR49 Headlamp Low
Beam Relay[/TD]
[TD]----[/TD]
[TD]E13L Headlamp Assembly - Left (T4A)
OR
Fuses F24UA, F25UA (T4F)[/TD]
[/TR]
[TR]
[TD]K07[/TD]
[TD]7[/TD]
[TD]KR23A Fuel Pump
Relay[/TD]
[TD]----[/TD]
[TD]G12 Fuel Pump[/TD]
[/TR]
[TR]
[TD]K08[/TD]
[TD]8[/TD]
[TD]KR42R Daytime
Running Lamp Relay
- Right[/TD]
[TD]----[/TD]
[TD]E13R Headlamp Assembly - Right (T4A)[/TD]
[/TR]
[TR]
[TD]K09[/TD]
[TD]9[/TD]
Relay[/TD]
[TD]----[/TD]
[TD]E11 Fuel Heater (Diesel)[/TD]
[/TR]
[TR]
[TD]K10[/TD]
[TD]10[/TD]
[TD]SPARE[/TD]
[TD]----[/TD]
[TD]--------------------[/TD]
[/TR]
[TR]
[TD]K11[/TD]
[TD]11[/TD]
Low Speed Relay[/TD]
[TD]----[/TD]
[/TR]
[TR]
[TD]K12[/TD]
[TD]12[/TD]
[TD]KR20D Cooling Fan
[TD]----[/TD]
[/TR]
[TR]
[TD]K13[/TD]
[TD]13[/TD]
[TD]KR20A Cooling Fan
Medium Speed 1
Relay[/TD]
[TD]----[/TD]
[TD]G10 Cooling Fan Motor, Fuse F45UA[/TD]
[/TR]
[TR]
[TD]K14[/TD]
[TD]14[/TD]
[TD]KR73 Ignition Main
Relay[/TD]
[TD]----[/TD]
[TD]Fuses F32UA, F33UA, F49UA, F50UA, F51UA, F52UA, F53UA, F54UA[/TD]
[/TR]
Important: Relays listed below are non-serviceable Printed Circuit Board (PCB) relays and are internal to the block.
Relays |
[TR]
[TD]----[/TD]
[TD]----[/TD]
[TD]KR3 Horn Relay[/TD]
[TD]----[/TD]
[TD]Fuse F47UA[/TD]
[/TR]
[TR]
[TD]----[/TD]
[TD]----[/TD]
[TD]KR6 Rear Window
Washer Pump Relay[/TD]
[TD]----[/TD]
[TD]G24 Windscreen Washer Pump[/TD]
[/TR]
[TR]
[TD]----[/TD]
[TD]----[/TD]
[TD]KR7 Rear Window
Wiper Relay[/TD]
[TD]----[/TD]
[TD]M45 Rear Wiper Motor[/TD]
[/TR]
[TR]
[TD]----[/TD]
[TD]----[/TD]
[TD]KR11 Windscreen
[TD]----[/TD]
[/TR]
[TR]
[TD]----[/TD]
[TD]----[/TD]
[TD]KR29 A/C
Compressor Clutch
Relay[/TD]
[TD]----[/TD]
[TD]Q2 A/C Compressor Clutch[/TD]
[/TR]
[TR]
[TD]----[/TD]
[TD]----[/TD]
[TD]KR46 Front Fog
Lamp Relay[/TD]
[TD]----[/TD]
[TD]Fuse F26UA[/TD]
[/TR]
[TR]
[TD]----[/TD]
[TD]----[/TD]
[TD]KR48 Headlamp
High Beam Relay[/TD]
[TD]----[/TD]
[TD]Fuses F22UA, F41UA[/TD]
[/TR]
[TR]
[TD]----[/TD]
[TD]----[/TD]
[TD]KR94 Fuel Door
Release Actuator
Relay[/TD]
[TD]----[/TD]
[TD]M27 Fuel Door Unlatch Actuator[/TD]
[/TR]
[TR]
[TD]----[/TD]
[TD]----[/TD]
[TD]KR95A Tailgate
Release Relay[/TD]
[TD]----[/TD]
[TD]Fuse F11UA[/TD]
[/TR]
70
6:th-Oct-2014, 11:31:50
(This post was last modified: 31:st-Mar-2022, 18:54:18 by Rusty2009.)
X51A Fuse Block - Instrument Panel Top View Fuses
Tip
Instrument Panel Fuse Blocks in vehicles built between 18-May-2010 and 29-June-2010 may have mixed up
fuse numbers on the block for fuses 15, 16, and 17. The numbering in the above graphic is correct for all
model year 2010 vehicles and should be used when trying to find the correct position of fuses 15, 16, or 17.
X51A Fuse Block - Instrument Panel Usage Fuses
Fuse Block Instrument Panel |
[TR]
[TD]No.[/TD]
[TD]Rating[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]----[/TD]
[TD]F1DA Fuse[/TD]
[TD]10A[/TD]
[TD]A22 Radio Control, K33 Driver Information Centre (DIC) Display[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]----[/TD]
[TD]F2DA Fuse[/TD]
[TD]20A[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]----[/TD]
[TD]F3DA Fuse[/TD]
[TD]25A[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]----[/TD]
[TD]F4DA Fuse[/TD]
[TD]20A[/TD]
[TD]A11 Radio, P5 Chime Alarm Control Module[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]----[/TD]
[TD]F5DA Fuse[/TD]
[TD]7.5A[/TD]
[TD]A12 Digital Radio Receiver Control Module, K82 Mobile Telephone Control Module, T11 Multimedia Player Interface Module
[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]----[/TD]
[TD]F6DA Fuse[/TD]
[TD]20A[/TD]
[TD]X80G Accessory Power Receptacle - Instrument Panel[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]----[/TD]
[TD]F7DA Fuse[/TD]
[TD]20A[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]----[/TD]
[TD]F8DA Fuse[/TD]
[TD]30A[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]----[/TD]
[TD]F9DA Fuse[/TD]
[TD]30A[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]----[/TD]
[TD]F10DA Fuse[/TD]
[TD]30A[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]----[/TD]
[TD]F11DA Fuse[/TD]
[TD]40A[/TD]
[TD]K8 Blower Motor Control Module[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]----[/TD]
[TD]F12DA Circuit Breaker[/TD]
[TD]25A[/TD]
[TD]64D Seat Adjuster Switch - Driver, S65D Seat Lumbar Support Switch - Driver[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]----[/TD]
[TD]F14DA Fuse[/TD]
[TD]7.5A[/TD]
[TD]X84 Data Link Connector[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]----[/TD]
[TD]F15DA Fuse[/TD]
[TD]7.5A[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]----[/TD]
[TD]F17DA Fuse[/TD]
[TD]10A[/TD]
[TD]A26 HVAC Control, K33 HVAC Control Module[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]----[/TD]
[TD]F18DA Fuse[/TD]
[TD]30A[/TD]
[TD]KR104A Logistic Mode Relay 1[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]----[/TD]
[TD]F19DA Fuse[/TD]
[TD]20A[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]----[/TD]
[TD]F20DA Fuse[/TD]
[TD]5A[/TD]
[TD]K85 Passenger Presence Detection Module[/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]----[/TD]
[TD]F21DA Fuse[/TD]
[TD]10A[/TD]
[TD]P16 Instrument Cluster[/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]----[/TD]
[TD]F22DA Fuse[/TD]
[TD]5A[/TD]
[TD]S39 Ignition Switch[/TD]
[/TR]
[TR]
[TD]23[/TD]
[TD]----[/TD]
[TD]F23DA Fuse[/TD]
[TD]20A[/TD]
[/TR]
[TR]
[TD]24[/TD]
[TD]----[/TD]
[TD]F24DA Fuse[/TD]
[TD]20A[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]26[/TD]
[TD]----[/TD]
[TD]F26DA Fuse[/TD]
[TD]20A[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]K1[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]K2[/TD]
[TD]----[/TD]
[TD]Logistic Mode Relay 1 KR104A[/TD]
[TD][/TD]
[TD]F1DA, F4DA, F5DA[/TD]
[/TR]
[TR]
[TD]K3[/TD]
[TD]----[/TD]
[TD]Auxiliary Power Relay KR70[/TD]
[TD][/TD]
[TD]F6DA, F7DA[/TD]
[/TR]
![[Image: vx.o.c.jpeg]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Logo/vx.o.c.jpeg)
70
6:th-Oct-2014, 11:56:58
(This post was last modified: 31:st-Mar-2022, 18:55:12 by Rusty2009.)
X53A Fuse Block - Rear Body Label
X53A Fuse Block - Rear Body Label Usage
Fuse Board Rear |
[TR]
[TD]No.[/TD]
[TD]Device
Label Name
[/TD]
[TD]Device
Assigned
Name
[/TD]
[TD]Rating[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]----[/TD]
[TD]F1RA Fuse[/TD]
[TD]40A[/TD]
[TD]K101 Trailer Interface Control Module[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]----[/TD]
[TD]F2RA Fuse[/TD]
[TD]30A[/TD]
[TD]X88 Trailer Connector[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]---[/TD]
[TD]F3RA[/TD]
[TD]5A[/TD]
[TD]Parking sensors[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]----[/TD]
[TD]F7RA Fuse[/TD]
[TD]10A[/TD]
[TD]K29 Seat Heating Control Module, K104P Seat Lumbar Control Module -
Passenger
[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]----[/TD]
[TD]F8RA Fuse[/TD]
[TD]5A[/TD]
[TD]K38 Ultrasonic Intrusion Sensor Module, P25 Power Sounder[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]----[/TD]
[TD]F11RA Fuse[/TD]
[TD]5A[/TD]
[TD]K65 Tyre Pressure Indicator Module, K68 Trailer Lighting Converter[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]----[/TD]
[TD]F13RA Fuse[/TD]
[TD]20A[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]----[/TD]
[TD]F15RA Fuse[/TD]
[TD]7.5A[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]----[/TD]
[TD]F16RA Fuse[/TD]
[TD]5A[/TD]
[TD]A10 Inside Rearview Mirror[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]----[/TD]
[TD]F17RA Fuse[/TD]
[TD]20A[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]----[/TD]
[TD]F19RA Fuse[/TD]
[TD]10A[/TD]
[TD]K32 Heated Steering Wheel Control Module[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]----[/TD]
[TD]F20RA Fuse[/TD]
[TD]20A[/TD]
[TD]K61 Sunroof Control Module[/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]----[/TD]
[TD]F21RA Fuse[/TD]
[TD]25A[/TD]
[TD]K29 Seat Heating Control Module[/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]23[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]24[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]26[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]27[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]28[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]29[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]31[/TD]
[TD]----[/TD]
[TD]F31RA Fuse[/TD]
[TD]30A[/TD]
[TD]T3 Audio Amplifier[/TD]
[/TR]
[TR]
[TD]32[/TD]
[TD]----[/TD]
[TD]F32RA Fuse[/TD]
[TD]10A[/TD]
[TD]K19 Suspension Control Module[/TD]
[/TR]
[TR]
[TD]K1[/TD]
[TD]----[/TD]
[TD]Ignition 0 Relay
KR72A
[/TD]
[TD]----[/TD]
[TD]F11RA, F16RA, F17RA[/TD]
[/TR]
[TR]
[TD]K2[/TD]
[TD]----[/TD]
[TD]Ignition 1 Relay
KR72B
[/TD]
[TD]----[/TD]
[TD]F13RA, F19RA[/TD]
[/TR]
[TR]
[TD]K3[/TD]
[TD]----[/TD]
[TD]Door Lock
Relay KR97
[/TD]
[TD]----[/TD]
[TD]A23D Door Latch Assembly - Driver, A23LR Door Latch Assembly - Left
Rear, A23P Door Latch Assembly - Passenger, A23RR Door Latch
Assembly - Right Rear
[/TD]
[/TR]
[TR]
[TD]K4[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
[TR]
[TD]K5[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]----[/TD]
[TD]Not Used[/TD]
[/TR]
14
Threads: 0
Car: Astra J 2010
Hi all. I am looking at wiring a tow bar relay up to an after market towbar. I know it needs a relay so as not to mess with the canbus. My question is I have noticed that fuse position 5 in the rear fuse box has a pin sticking out of it. I cannot find any listing for fuse 5 on any diagrams. I noticed on another thread on this site that a user hooked up to fuse 5 for heir trailer relay power source. Can anyone tell me if this will cause any issue to the cars computer by doing this. The other thread used a female spade connector to bridge onto the pin. Thanks. James
70
(22:nd-Jul-2018, 21:47:38)James3866 Wrote: Hi all. I am looking at wiring a tow bar relay up to an after market towbar. I know it needs a relay so as not to mess with the canbus. My question is I have noticed that fuse position 5 in the rear fuse box has a pin sticking out of it. I cannot find any listing for fuse 5 on any diagrams. I noticed on another thread on this site that a user hooked up to fuse 5 for heir trailer relay power source. Can anyone tell me if this will cause any issue to the cars computer by doing this. The other thread used a female spade connector to bridge onto the pin. Thanks. James
That would of been my car with the tow-bar wiring.
There was no relay used in the system & there was no issues with the canbus at all.
Fuse on 5 as far as I've been able to find is not used for anything at all.
Threads: 4
Car: Opel Astra J 1.6 CDTi
I checked my trunk and there is no rear fuse box. Where could it be?
70
(9:th-May-2019, 14:14:23)_Mita Wrote: I checked my trunk and there is no rear fuse box. Where could it be?
Some don't have a rear fuse-board.
Threads: 4
Sorry, somehow missed your reply.
What would that mean, that I don't have any wiring for rear parking sensors, seat heating, etc.?
70
You can add to the glove-box fuse board for these things.
The annoying thing is there is no info on TIS for the wiring info for front fuse boards only yet some come out the factory with parking sensors and heated seats but no rear fuse board.
Threads: 4
That sure sounds annoying.
Thanks for the info!
