6 gtc 136 cdti rail fuel sensor 1 location?
Gtc 1.6 cdti 136 fuel rail sensor location?
I have a 2015 1.6 cdti 136 Astra GTC, I’m trying to locate the fuel rail sensor but cannot seem to find it. Could anyone point it out for me please?
I'm not sure if it's in the same place but it's here on my 2.0cdti.
[Image: e713f794425f2832de1c6ba6435697dc.jpg]
Sent from my SM-G950F using Tapatalk
(10:th-Nov-2018, 17:42:28)Rusty2009 Wrote: I'm not sure if it's in the same place but it's here on my 2.0cdti.
Thank you for your reply, I tried to attach a photo but it failed to uphold originally. I have found images for the 2.0 cdti engine but not for the 1.6, it is located in a different place. Could anyone help me out and point it out on this photo?
is it on the other end?
The bar is in same location.
  Exhaust Gas Temperature Sensor P2084 bagnallman 4 13,001 2:nd-Sep-2021, 08:17:51
Last Post: geoffsnook
Thumbs Up ABS sensor/ fault codes wrobsongtc 8 11,875 26:th-Mar-2021, 13:49:53
  DPF problems cold weather 1.7 cdti 110 hp A17DTE seekar 1 6,003 19:th-Dec-2020, 22:27:52
Last Post: Kiel0777
  Astra J 1.7CDTi - Boost sensor location for Chipbox jason.dexter 8 14,972 4:th-Feb-2019, 14:40:25
Last Post: rlievens
  Astra J 1.7 CDTI Tech-Line rear light cluster issue AstraCDTI 1 8,877 29:th-Aug-2018, 07:27:16
  Tpms sensor. Htid 5 8,986 21:st-Feb-2018, 20:43:06
Last Post: Htid
  Re-map astra j 2.0 cdti ecoflex kyle-astra-j 8 12,242 4:th-Feb-2018, 22:55:44
Last Post: Iaintruten
  Fuel filter change everson38 6 10,749 29:th-Nov-2017, 09:49:01
Last Post: rlievens
  1.6 CDTI engine problems ? Loddy Jeff 1 10,144 17:th-Aug-2017, 08:36:49
Last Post: Jerry
  Re-mapping 2.0 CDTI S/S Steveb19111978 7 10,622 27:th-Jul-2017, 17:55:48
Last Post: seosamh1968
