help need
Need help
Found this wire behind the radio can is it the centre speaker wire ??
[Image: 76190c43b00a1d147b22c7474c2e1985.jpg]
No it's not the centre speaker.
Ok thanks. Do you know if there will be a speaker wire or is it just pot luck if there is
pot luck, I had to add the wiring and plug to my vxr
you need a 'Brown/blue and Yellow' wiring + plug
Mine I found on the right side where all the wires are and where you have 2 black cables have a look there.
