wiring diagram
Wiring diagram
hi can anyone provide me with a wiring diagram for the a20dth engine.
I need to find what pin on the ecu is for the lambda sensor and test from that end.
Many thanks.
Please see attached.
.pdf   K20 Engine Control Module X1 (LBS).pdf (Size: 44 KB / Downloads: 23)
.pdf   K20 Engine Control Module X2 (LBS).pdf (Size: 37.43 KB / Downloads: 17)
  wiring info niteram 2 4,580 17:th-May-2020, 14:19:45
  Wiring Diagram [Internal Lights] cubez0 3 6,541 25:th-Jun-2018, 11:28:03
  Schematic Diagram needed vagepap 5 7,002 28:th-May-2016, 16:16:30
Last Post: vagepap
jas7c5-2008 (8:th-Feb-2025, 19:39:06), dellpiron (27:th-Apr-2025, 19:22:33)
