problems idle
Idle problems
Had this problem for a while , it’s the 1.7 110 sports tourer .
Basically the revs move up and down at idle and vibrates , it’s like a weird heart beat but feels like it’s about to stall every time it drops
Anybody know why it does it , had full service couple month back but done it for ages
Many thanks
1.7cdti are common for the suction control valve to cause engine surging.
(24:th-Jul-2018, 09:17:33)stigeye Wrote: 1.7cdti are common for the suction control valve to cause engine surging.
I have heard this is it a hard job to do
(28:th-Jul-2018, 08:35:35)Rusty2009 Wrote:
Wow thanks that’s exactly same as ours , just to clear will I need to tech 2 I got lost at end of vid
Only if it's showing a high reading on fuel while on tick over
(28:th-Jul-2018, 14:32:08)Rusty2009 Wrote: Only if it's showing a high reading on fuel while on tick over
U mean fuel consumption? I don’t have the inst fuel display on mine so I won’t know what it’s using , or do u mean the fuel gauge going down more than normal thanks rusty
Yes instant fuel on dash. ah you have basic display?
Yeah mate I have Opcom for my veccy but could never get the vauxcom to work so couldn’t activate the range or if it’s possible I don’t know
What version op-com are you using?
(30:th-Jul-2018, 07:42:37)Rusty2009 Wrote: What version op-com are you using?
Not sure but furby on here put it on remotely I can check tonight
[Image: 23a53b13968973b486e15d0e005dffeb.jpg] this is my Opcom rusty I haven’t used used it on the Astra yet but could this activate the fuel consumption do u think ?
Thanks again mate
Yes it should do it's the version I used.
  Please help, strange problems. Richiew1986 8 4,185 27:th-Jul-2021, 21:29:12
Last Post: Richiew1986
  DPF problems cold weather 1.7 cdti 110 hp A17DTE seekar 1 3,113 19:th-Dec-2020, 22:27:52
Last Post: Kiel0777
  1.6 CDTI engine problems ? Loddy Jeff 1 7,884 17:th-Aug-2017, 08:36:49
Last Post: Jerry
danjo91 (14:th-May-2024, 18:16:09)
