5:th-Jan-2018, 12:53:09
I guess you'll burn your clutch as well Iaintruten
Tags |
progress sparkyscfc74’s thread |
5:th-Jan-2018, 12:57:29
(This post was last modified: 5:th-Jan-2018, 12:57:57 by Iaintruten.)
yes it's already slipping now and again goes through phases so needs done but trying to find something better than standard with regards the clutch and flywheel plus trying to decide weather to fit a limited slip diff to keep the traction down but it's where to stop spending money as it is only a diesel and not a performance car but I like the idea of it been unique .
5:th-Jan-2018, 13:00:28
That’s what makes it good mate we’re all different
5:th-Jan-2018, 16:24:43
I'm really tempted to have on of these illuminated gear knobs from Germany, but at over £90 it's a bit pricey! You can configure the light colour, stitching colour and finish.
https://www.ebay.co.uk/itm/gear-gaiter-s...Swt5hYdPHa
5:th-Jan-2018, 17:21:28
Dose look good but £90 is abit extreme and over priced
5:th-Jan-2018, 17:25:44
Yeah that’s my thoughts.
6:th-Jan-2018, 13:34:58
Just fitted my RaceChip XLR pedal box and all I can say is OMG!!! I didn’t think it would make a lot of difference but it does. As suspected I can’t put it on race or race + as it makes it spin to much albeit on a greasy road surface so at the moment I have it in sport + which along with the short shifter has completely changed the driving experience!!! I’ve definitely changed my mind about the engine chip which I’ll be ordering at the end of the month
I’ve put the controller here Don’t know if I’ll keep it there but it will do for now. Sent from my iPhone using Tapatalk
6:th-Jan-2018, 13:41:13
Looking good mate think I may be tempted to order one now and see how it goes . May be single by the end of the month but as long as the car is performing good that's fine .
6:th-Jan-2018, 14:18:44
I’d recommend it mate, if you go on eBay and search for Haz motorsport they’re £188.89 but he accepts £180. The RaceChip engine mod is £129 direct with free shipping
6:th-Jan-2018, 15:02:34
No problem will have a look mate cheers, time for me to get busy anyway as that's the replacements connectors came for the heated seats touch wood this will fix them or I'll need to order the pads lol.
6:th-Jan-2018, 15:04:32
7:th-Jan-2018, 15:03:21
I'm even more impressed with my pedal box now as this morning it was very icy in my street which is also an incline, so I put it in economy+ mode which really lowers the revs and I had no wheel spin whatsoever!!! So not just for driving like a nutter is has a practical purpose too
8:th-Jan-2018, 08:12:11
Would you say it's any better than the DTUK pedal box or haven't you tried that one?
8:th-Jan-2018, 09:47:12
I’ve not tried that one so can’t really compare. What I can say is that there is a distinctive difference between the 7 settings on the RaceChip that will suit all driving styles/conditions. I’m definitely going to order the engine chip at the end of the month
14:th-Jan-2018, 16:05:26
My RaceChip S has now ordered so should be here by my birthday on Friday
It’s now a birthday present from my mum and sister! So the missus is going to get me an illuminated gear knob from Germany Sent from my iPhone using Tapatalk
14:th-Jan-2018, 16:14:55
Not bad you will definately notice the difference mate just be prepared to buy tyres and a new clutch lol, I'm just in the middle of stripping the auxilary belt off mine since it makes a noise in colder mornings on start up, thought it was the water pump but that's changed so will start it tomorrow with no auxiliary belt and hopefully no noise lol.
14:th-Jan-2018, 16:19:38
Yeah I’m still getting used to the instant power I get with the throttle box!!! I thought the illuminated gear knob was expensive but as I’m now having it as a present I don’t have to worry about that part
Wish I could do more mechanical stuff, I’d save a fortune on garage bills Sent from my iPhone using Tapatalk
14:th-Jan-2018, 16:38:16
Lol I just learnt it over time as I'm actually a spark Lol, cars is my hobbie and at times look for a reason to pull it to bits lol. My clutch slips now and again with the power going through mine as you will eventually probably find but then stops slipping for months then may come back and go away again lol.
15:th-Jan-2018, 15:33:57
Downloaded some more packs for my Torque Pro App
15:th-Jan-2018, 16:33:41
Like it witch odb device have you got
15:th-Jan-2018, 17:15:27
(This post was last modified: 15:th-Jan-2018, 17:20:23 by sparkyscfc74.)
Just a cheap one off eBay think it was less than £4 I’ll try to find the link
Sent from my iPhone using Tapatalk This is the one https://m.ebay.co.uk/itm/Mini-Bluetooth-...2617059752 Sent from my iPhone using Tapatalk
16:th-Jan-2018, 19:55:59
RaceChip coming tomorrow, hopefully I’ll have time to fit and test it I’ll post tomorrow with what I think of it
17:th-Jan-2018, 17:12:08
So my RaceChip arrived today and after an hour of trying to find the boost sensor because they’d sent me the wrong picture then a phone call to Germany for the fine tune settings I got it fitted I also found out that they’ve upgraded my chip to the 39hp RS chip because they hadn’t got the circuit board for the 32hp S chip!!!
Anyway I gave it test drive and on it’s highest setting it’s a massive difference along with the throttle box it’s absolutely mad!!! I don’t know if I’ll keep it on max but I will for now because it’s fun Sent from my iPhone using Tapatalk
19:th-Jan-2018, 14:45:14
Ordered my illuminated gear knob today, gone for red led and red stitching. Might take up to 2 weeks to arrive though.
22:nd-Jan-2018, 22:44:03
Thought I’d give a little update on the RaceChip, after driving with it for about 100 miles I’m happy to report I’ve had absolutely no problems with it whatsoever. It’s still on it’s highest setting and I’ve had no smoking and no warning lights I did have a caution on my Torque app saying that the fuel rail pressure and boost pressure had increased but that’s what the chip is supposed to do so at least I know it’s definitely working! It’s a really good driving experience with the throttle box and short shifter 50 to 80mph from 3rd gear upwards is phenomenal but you can tone it down when you need to. Both the chip and the throttle box claim to improve Mpg so next time I fill up I’m going to see what I’m getting then I’ll post my findings
23:rd-Jan-2018, 09:43:15
Very nice sparky!
23:rd-Jan-2018, 12:32:37
Much to my surprise my illuminated gear knob arrived from Germany this morning!!! They’d quoted a 2 week time frame but I only ordered it Friday. So it’s just taking me 20 minutes to wire it up and fit and I’m really pleased with the results. It is very good quality, feels nice and looks good.
I’ll post a night time picture later, but first impressions are it’s certainly bright enough Sent from my iPhone using Tapatalk
23:rd-Jan-2018, 12:41:42
Nice look on the illumination, however am I mad that I prefer the original vx shape?
23:rd-Jan-2018, 12:44:20
No mate, not at all. It feels a lot chunkier than the original which I quite like.
23:rd-Jan-2018, 15:56:52
Yeah the original one definitely has a more streamlined look.
Build quality looks good!
23:rd-Jan-2018, 19:13:00
(This post was last modified: 23:rd-Jan-2018, 19:14:45 by sparkyscfc74.)
I’ve got another little interior light job at the weekend but I’m not going to say what unit I’ve seen if it’s possible to do then if it looks good I have seen it done but there’s no tutorial for it so fingers crossed ??
Sent from my iPhone using Tapatalk That’s providing the parts arrive by Saturday Sent from my iPhone using Tapatalk
23:rd-Jan-2018, 20:28:47
Damn, that's just teasing!
Installing a disco ball? Sent from my SM-G935F using Tapatalk
23:rd-Jan-2018, 21:47:15
Close........but no hopefully it won’t be that cheesy!!!!
23:rd-Jan-2018, 22:04:27
You are installing a raclette powered by an LED heatsink??
Now THAT would be a car id buy! Sent from my SM-G935F using Tapatalk
23:rd-Jan-2018, 23:48:50
Night shot
24:th-Jan-2018, 00:46:17
Looking good
24:th-Jan-2018, 13:28:33
(This post was last modified: 24:th-Jan-2018, 14:12:50 by sparkyscfc74.)
Bought a genuine ashtray/storage tub, I’ve put chewing gum in it
Sent from my iPhone using Tapatalk Parts have arrived for my weekend job and had a quick try and it looks like it will work so I’ll post some pictures when it’s done Sent from my iPhone using Tapatalk
26:th-Jan-2018, 11:36:19
I got impatient as usual and didn’t want to wait until tomorrow so I’ve done my interior lights job yesterday and finished it today. I ordered some of these earlier in the week https://m.ebay.co.uk/orderDetails?itemId...1849340660 and have wired them in and inserted them into the door cards between the plastic and leather. I was going to wire them to the ambient lights in the doors but the power didn’t seem to be 12 volts for some reason and they didn’t look that bright so I’ve wired them to the window switches instead and they’re now brighter and they dim on the switch like the rest of the lights!!! Apologies for the quality of the pictures as my phone camera is not that good but I will post some more pictures with a decent camera later
Looks really good at night but like I said my camera hasn’t picked up the colour very well. Sent from my iPhone using Tapatalk
26:th-Jan-2018, 12:39:24
Link didn't work properly
https://www.ebay.co.uk/itm/1M-2M-3M-Flex...2749.l2649
26:th-Jan-2018, 14:28:34
Got a link for that gear knob?
26:th-Jan-2018, 14:31:38
Yeah a few posts back
26:th-Jan-2018, 14:42:21
Very nice result!
26:th-Jan-2018, 15:05:14
(5:th-Jan-2018, 16:24:43)sparkyscfc74 Wrote: I'm really tempted to have on of these illuminated gear knobs from Germany, but at over £90 it's a bit pricey! You can configure the light colour, stitching colour and finish. Link for gear knob Steve Sent from my iPhone using Tapatalk
Looks very smart
26:th-Jan-2018, 18:03:00
Cheers mate only cost less than £8 and 30 minutes per door!
26:th-Jan-2018, 20:58:14
(26:th-Jan-2018, 15:05:14)sparkyscfc74 Wrote:(5:th-Jan-2018, 16:24:43)sparkyscfc74 Wrote: I'm really tempted to have on of these illuminated gear knobs from Germany, but at over £90 it's a bit pricey! You can configure the light colour, stitching colour and finish. Cheers. Are they easy to wire in?
26:th-Jan-2018, 21:24:52
Yeah I wired mine straight to the 12 volt socket
27:th-Jan-2018, 08:50:23
Not too sure on the shape of the gear knob, but looks good.
I've got the lighting to put in my door cards too just not got round to it yet, I have done a strip across the dash. Astra-J 2.0 CDTI S/S
27:th-Jan-2018, 08:53:26
I’ve got another strip coming for the dash
27:th-Jan-2018, 09:13:09
I like the el wire look, but I would like to have some kind of programmability to it: e.g. have it pulse/chase the light down the strip to mean different things.
It may be possible to use pwm to control brightness, do something like use it to indicate music volume in the dash strip Sent from my SM-G935F using Tapatalk |
Progress thread Rusty2009 | Rusty2009 | 416 | 204,424 |
27:th-Mar-2022, 09:32:35 Last Post: Rusty2009 |
Progress thread : White Astra 2.0 Cdti Sri vx line | marcus | 193 | 104,435 |
Progress thread - AstraRT | AstraRT | 5 | 5,059 |
10:th-Jan-2021, 08:35:22 Last Post: Rusty2009 |
Qaranc's Astra progress | Qaranc | 12 | 10,550 |
Alex's Progress Thread | AlexFitton | 95 | 48,373 |
27:th-Jun-2020, 08:53:48 Last Post: Rusty2009 |
JohnL's VXR Progress thread | JohnL | 17 | 15,221 |
15:th-Feb-2020, 12:38:28 Last Post: olihil18 |
Where's my thread? | Telsun | 2 | 4,003 |
1:st-Jan-2019, 09:49:57 Last Post: Telsun |
Progress Thread Conor97 | Conor97 | 28 | 15,165 |
9:th-Sep-2018, 19:37:44 Last Post: Conor97 |
Progress Thread: Sheppy1 | sheppy1 | 1,759 | 813,000 |
30:th-Aug-2018, 09:45:17 Last Post: sparkyscfc74 |
Progress thread sports tourer | chills21 | 6 | 8,198 |
5:th-May-2018, 17:12:03 Last Post: Steveb19111978 |
Who read this thread? |
1 User(s) read this thread: |
iNeoTom (4:th-Mar-2024, 21:45:40) |
