satnav m072
m072 satnav
hi guys quick question,
what satnav does everyone use of the m072 cus i think igo is awful cant even put in a postcode so its a nightmare to use, i wanted to use google maps but i dont no how or if you can use it just using gps as i cant really use my phone as a wifi hotspot as i have a rubbish contract and only get 1gb of data, can anyone help with a better one that just uses gps or can you even use google maps wit just gps and if so how?
thanks in advance
james
I use Waze when tethered but if I had no connection I've bought co-pilot which works offline.
Sent from my ONEPLUS A3003 using Tapatalk
I use Google maps mainly due to the excellent traffic updates. Yes you need a wifi connection to do that. Google maps will work in offline mode but without traffic.
I have sygic as well. Pretty good now that the application has evolved over the last while.
Past 2008 Civic 1.8 Type S
I use Waze. Best smartphone GPS app there is. Up to date traffic info is the best..
Of you don't want to use your mobile data connection you will never get traffic info, whatever app you use.
Without internet your options are limited too:
- Google maps: You have to download the area on your home wifi and save it to your smartphone. This function is called "Offline Area's". If you leave the area you downloaded you won't see any roads or addresses. Positive: You can just "googl" an address in the app.
- TomTom GO Mobile: You can download whole countries for free (again on your home WiFi) and use it without data connection for 75km/month (I'm guessing 50 miles/month for you guys). If you drive more than that (I'm sure you do) then you will have to pay for the app. This is about 20 pounds a year I think. Negative: you have to know the exact address.
- HERE WeGo: Same as TomTom but totally free. But they totally updated the app a few months ago and a lot of people don't like it anymore.
The best you can do is use Waze. It doesn't use that much data. And there are a tip to reduce data usage:
- Start the directions to your location in a place where you have a WiFi connection. That way Waze will download all the roads on the wifi and it remembers them when you are on the road even without Mobile data turned on. But if you deviate from that route it won't have the roads loaded.
As you see, you don't always need a good mobile data connection, it will still function as long as you have a GPS connection. And it doesn't use that much data (unless all you do is drive around with it all day).
That's about all I could think off Smile
  Front DVR android S160 M072 NEATH-LAD 3 6,193 4:th-Jul-2019, 19:07:39
  W072 (M072 Successor) Pre-Release Information sheppy1 18 18,559 2:nd-Jun-2018, 12:19:24
  M072/ Bluetooth/Torque issue CraigSRi 5 8,907 19:th-Jan-2018, 15:31:14
Last Post: CraigSRi
  M072 drama when disconnecting the battery marcus01 0 5,835 14:th-Jun-2017, 14:50:55
  M072 help. Spud7997 2 6,435 14:th-Jun-2017, 14:33:11
  S160/M072 Kotix Rom Discussion marcus01 2 7,901 11:th-Jun-2017, 22:59:06
Last Post: Spud7997
  Kotix Custom ROM for the Android S160 (M072) Head Unit marcus01 2 10,978 29:th-May-2017, 08:33:30
  M072 (S160) Android Head Unit Install/Info sheppy1 654 571,930 21:st-May-2017, 12:55:12
  M072 fitted Jhill7168 1 5,690 21:st-May-2017, 12:33:55
  m072 ordered! sd card question jamesh7168 19 18,747 21:st-May-2017, 12:32:11
