Threads: 20
Car: astra j
hi all, I am new to this site so all help is welcome,
I have a 2012 astra j mk6 1.7d estate with small display between clocks that shows mileage and trip,
what I would like to know is there any way I can unlock the settings so that I can get things like mpg etc,etc,
or can I change my clocks for the one that as the large display if that`s possible.
would aKWP-2000 or a OP COM OBD2 be any use to me.
many thanks to you all ...........
Thanks Received: 8 in 8 posts
73
Welcome to VXOC.
the MPG can be turned on & a 1 or 2 more things but nothing major.
you could upgrade the IPC if you have the right cruise control switch but you'd need to know what else needs doing.
Not really although you could use op-com to turn on the extra menus on the IPC and read fault codes you couldn't do much in the way of programming with it.
If you did get yourself an op-com do not buy cheap rubbish off ebay buy from http://www.op-com.co.uk/
Threads: 20
Car: astra j
(14:th-Jul-2017, 07:27:22)Rusty2009 Wrote: Welcome to VXOC.
hi, thanks for your reply.
can you tell me what you mean by (ipc) and what you mean about the right cruise control switch.
73
IPC = Instrument cluster which is your speedo or clocks.
To up grade from the half screen to mid level or up level you need the switch like this.
Threads: 20
Car: astra j
20:th-Jul-2017, 17:30:13
(This post was last modified: 20:th-Jul-2017, 17:34:31 by marky79.)
(15:th-Jul-2017, 07:01:54)Rusty2009 Wrote: IPC = Instrument cluster which is your speedo or clocks.
![[Image: Vauxhall-Astra-J-Estate-2009-2015-Steering.jpg]](https://www.picclickimg.com/d/l400/pict/322430842394_/Vauxhall-Astra-J-Estate-2009-2015-Steering.jpg)
(13:th-Jul-2017, 22:51:46)marky79 Wrote: hi all, I am new to this site so all help is welcome,
so if I get myself the cruise control switches I can change the ipc, do you know any part numbers for the ipc mid or upper level,
Threads: 20
Car: astra j
73
If you don't have the switch I posted above you can't fit it, I'm working on it but it takes time.
Threads: 0
Car: Astra j
(20:th-Jul-2017, 19:37:01)marky79 Wrote: so if I get myself the cruise control switches I can change the ipc, do you know any part numbers for the ipc mid or upper level,
my bro got a j this morning hes got the right c/c switch and a full screen how can the mpg screen be turned on hes only got trip 1 and trip 2
73
(22:nd-Jul-2017, 22:27:47)Hunty Wrote: (20:th-Jul-2017, 19:37:01)marky79 Wrote: so if I get myself the cruise control switches I can change the ipc, do you know any part numbers for the ipc mid or upper level,
By seeing me or someone with the equipment & know how to do it.
Threads: 20
Car: astra j
hi if I get the cruise control switches and some other clocks and fit them will you be able to program for me.
and do you know what part number do I need for the clocks as my have seen some on e-bay.
how far are you away are you has I am in Stevenage.
many thanks..............
73
(5:th-Aug-2017, 20:45:34)marky79 Wrote: hi if I get the cruise control switches and some other clocks and fit them will you be able to program for me.
(22:nd-Jul-2017, 07:13:48)Rusty2009 Wrote: If you don't have the switch I posted above you can't fit it, I'm working on it but it takes time.
